Old 06-30-2005, 11:58 PM   #1
Robert Winterbottom
Guest
Posts: n/a
I just recently acquired a stock 1990 supra with a brand new 7M-GE motor, so fai there is an HKS Intake kit and an A'Pexi super air flow converter in it so far. I want to know what I need to upgrade in order to eventually bolt on a turbo, any input would be appreciated.
Old 07-01-2005, 12:06 PM   #2
ddmcse
ddmcse's Avatar
add a nice big CAT BACK exhaust and have a blast
forget the turbo
300+ RW HP Dyno run,
Blown HeadGasket info
My Supra KiXGaS
Old 07-01-2005, 08:25 PM   #3
KingDiamond
KingDiamond is on a distinguished road
well if your looking to add a turbo where you going to be pushing some serious boost, you'll need to swap out the engine to a 7mgte, of couse the ecu, engine wiring harness. You'll also have to make sure your car has an lsd, and i'm not sure if there is a difference in the transmissions, supra girl would definately know, or one of the other more experienced turbo members on here.
KingDiamond is offline   Reply With Quote
Old 07-02-2005, 11:06 AM   #4
skunk
skunk's Avatar
skunk is on a distinguished road
nitrous might be the key as long as the comp and fuel system are upgraded
skunk is offline   Reply With Quote
Old 07-02-2005, 07:47 PM   #5
monkihead
SP58GT
monkihead's Avatar
you dont need to swap the engine if you want to turbo it. you just wont be able to boost much. the 7m & 7mgte share the same bolt pattern for exhaust manifolds.
monique- better off dead
87 Supra won't start RNEMESiS42 MKIII Supra 3 06-25-2011 06:30 PM
Supra wont start Micahwc MKIII Supra 1 03-14-2008 05:57 AM
Supra won't start cmnetworx MKII Supra 2 07-31-2006 10:55 PM
87 Supra 7M-GTE/AT Engine cranks over but doesnt start... Supra-Boy MKIII Supra 7 03-15-2006 11:38 PM
