Old 06-18-2010, 03:31 AM   #21
907mge
907mge's Avatar
I only have a pulley driven fan and I can run around all day with the a/c, on a hot day, and be fine.
Did you check?
Coolant mixture
water pump
t-stat
air in the system
Old 06-18-2010, 03:34 AM   #22
batmmannn
batmmannn's Avatar
Default Checks
Yes I changed thermo, changed rad cap, burped it and burped it. I have not pulled the water pump.
Old 06-18-2010, 12:24 PM   #23
bryanf89
i recommend changing the water pump and check your thermostat housing sensors
Old 06-18-2010, 03:07 PM   #24
batmmannn
batmmannn's Avatar
Default Term sensors
How do you check the thermostat sensors? My temp guage works as it should. I thought there was only one. Please explain, Thanks
Old 06-18-2010, 08:26 PM   #25
batmmannn
batmmannn's Avatar
Default Success
FIXED IT!
Here is the explanation I didn't want to clutter up the board any worse than I have! Thanks so MUCH!
http://www.toyota-supra.info/forums/...html#post84699
Electric Fan Controller Temp. question SilenceboneSupra MKIII Supra 19 06-16-2010 08:27 PM
Pulling ICE and related parts and GOING ELECTRIC ddmcse MKIII Supra 6 12-11-2008 09:40 PM
Help on electric seat supratrd654 Non-Generation Specific Questions 1 03-14-2005 07:12 AM
Help!!! looking for electric seat diagram supratrd654 MKIII Supra 0 03-08-2005 03:17 PM
