Old 04-30-2008, 04:18 PM   #11
SideWinderGX
SideWinderGX is on a distinguished road
no: just that electric fans can be set to rotate both ways. you want the fans rotating so that air is pulled into the engine bay, pulling the air through the radiator into the engine bay.
i still havent found anything that compares the stock clutch's cooling capacity to an electric fans capacity ='( with a newer/bigger radiator it will be better regardless but id still like to know, for knowledge sake.
my car:
1987 brownish Toyota Supra Turbo, automatic 7MGTE engine with ~100k miles on it.
SideWinderGX is offline   Reply With Quote
Old 05-01-2008, 05:37 AM   #12
SilenceboneSupra
SilenceboneSupra is on a distinguished road
Originally Posted by mkiiisupra View Post
are your saying i need 2 fans? one in front and one in back of radiator?
yeah i think so, mrnickleye uses 3 as he has mentioned before becuz he lives in the "desert", i used 1 on mine and it was overheating but where i live it can be real hot outside sometimes 2 so i had to add another 1......
but i think with the 2nd you will be allright depending on where u live.... just my 2 cents......
SilenceboneSupra is offline   Reply With Quote
Old 05-01-2008, 07:58 AM   #13
sd88supra
sd88supra is on a distinguished road
Some cars actually come with one on the front and one on the back, as a pusher and puller. I don't know why, I just think they would be better as just pullers. If you're getting a bigger radiator be sure to get a large enough fan. If you live in very hot climate I'd go for a dual fan. I just have one large fan, but like MrNickleye, I have an override switch so I can keep it running whenever I want during hot days. In fact I think I might add another fan. Hot weather sucks. As far as the stock fan, don't worry about it, I guarantee it doesn't come near 2950 cfm. Take the load off your engine. It takes a much smaller load to recharge your battery.
-1987 5 spd N/A with TEMS: low miles! All stock with the exception of electric fans and an '89 front bumper, Yokohama 225/50/16 with stock rims. It's a mess and in the garage.
-1987 5 spd Turbo with TEMS: miss-matched tires, needs lots of work, but it runs! Project car.
-1988 N/A auto targa: all stock except 18" rims with Falken 265/35/18 in rear and 225/35/18 in front; daily driver.
sd88supra is offline   Reply With Quote
Old 05-01-2008, 12:07 PM   #14
mkiiisupra
sounds good ill definantly go with the electric. This cooling system upgrade is starting to get costly heh.
But im also relocating the oil filter and changing to 2 filters, redoing the lines, adding a oil cooler, redoing tranny lines and prolly use'n the old oil cooler for the tranny fluid
1990 Toyota Supra Turbo A/T
Old 06-18-2010, 02:11 AM   #15
batmmannn
batmmannn's Avatar
Default No Fan
Will an 87 NA supra overheat if the single electric fan is not functional? Thanks
Old 06-18-2010, 02:24 AM   #16
907mge
907mge's Avatar
Your fan for the engine is powered by the pulley not electric. I believe what you are talking about is for the a/c and not cooling the engine.
Old 06-18-2010, 02:34 AM   #17
bryanf89
the stock fan's cfm is measured from engine rpm, it varies. in case you didnt know CFM means cubic foot per minute
so if the fan is rated at 5900cfm that means it pushes/pulls 5900 cubic feet of free flowing air and each cubic foot of air is 1 unit of mass
Old 06-18-2010, 03:06 AM   #18
batmmannn
batmmannn's Avatar
Default Ok
Please understand I have an NA NON turbo. The fan is on the radiator it does not cool the condensor. I can't seem to get a straight answer as to if the fan not working can allow the car to overheat, from what I have read it is tripped either by the AC or the Temp sensor. Mine does not work at all, works if I hook it up direct to power, I swapped fan relays from my other car NO DIFFERENCE. Where do you guys run wires into the cab so I can switch this fan, I see no easy openings on the firewall. I don't have fans on my condensor I have one big 8 inch electric fan shrouded against the radiatior on the motor side just like an older MK2 celica supra non turbo. Thanks for your help I broke the tang thingie off my thrromostat and now am about to drill it.
Old 06-18-2010, 03:17 AM   #19
907mge
907mge's Avatar
You should have a fan powered by the engine pulley. If you do not it must be aftermarket. As far as I know every mk3 came with a belt driven fan and not electric.
Old 06-18-2010, 03:21 AM   #20
batmmannn
batmmannn's Avatar
Of course I have a pulley driven fan, I also have an 8 inch electric fan on the radiator not the condensor.
Electric Fan Controller Temp. question SilenceboneSupra MKIII Supra 19 06-16-2010 08:27 PM
Pulling ICE and related parts and GOING ELECTRIC ddmcse MKIII Supra 6 12-11-2008 09:40 PM
Help on electric seat supratrd654 Non-Generation Specific Questions 1 03-14-2005 07:12 AM
Help!!! looking for electric seat diagram supratrd654 MKIII Supra 0 03-08-2005 03:17 PM
