Old 04-02-2008, 12:20 PM   #1
jride1999
jride1999 is on a distinguished road
Default header question
My friend gave me his old ss header.My question is im trying to run stock turbo for now and the header has a wastegate flange on bottom,my turbo has one built in it,can i block the wastegate flange off an run stock turbo,or do i have to upgrade my turbo? alot of people told me diff things its an 89 turbo
jride1999 is offline   Reply With Quote
Old 04-02-2008, 01:24 PM   #2
j3pz
keep the stock manifold, it will out flow the turbo. also is the manifold (headers) flanged for a ct? if not you would need an adaptor. as for the question about whether or not you can block off the internal wg, dont see why not, but why bother?
Old 04-02-2008, 02:54 PM   #3
jride1999
i was gonna block it off becuse didnt think i can run 2 wastegates,and turbo has one built on it,i wanted to wait till winter time to get new turbo.So i should just run old manifold?
Old 04-02-2008, 03:00 PM   #4
jride1999
wont the aftermarket header give me more hsp then stock one?
Old 04-02-2008, 04:01 PM   #5
Chambers
Chambers's Avatar
It will increase flow and probably give you a few horses but I would keep the stock manifold on until you get a new turbo, If you move the stock turbo to a new location the oil and water lines will not reach it correctly and you will have to run new ones, so I would wait so when you get the new turbo you can put new oil lines in.
"Stuck in the 80's"
Old 04-02-2008, 04:41 PM   #6
jride1999
ok thanx ill just use old manifold till i get enuf money for new turbo.Now im still gonna run my new 3in downpipe and get a aftermarket elbo,to a cutout on end of downpipe,then run stock exhaust.question is should i use a cut out or do a straight 3 in exhaust? an how much hsp will that give me
Old 04-03-2008, 02:53 PM   #7
j3pz
personally a cut out isnt a bad idea, i would prefer an electric one but they are a lil more $$$. it depends if the extra work and money are worth the few hp it will free up, so the final sayso is up to you
Old 04-04-2008, 01:09 AM   #8
jride1999
thanx,doesnt cost that much,i can weld it on myself save me few bucks,just using car for drag strip
Question about 7m-gte. AzNbOi2626 MKIII Supra 3 03-29-2011 06:55 PM
Pre89 versus 89+ nose and support. lifesnotfair MKIII Supra 2 01-08-2010 09:06 PM
turbo or not ??? That's the question ... sausa MKIV Supra 7 03-30-2007 02:22 AM
header supra_91 MKIII Supra 4 04-13-2006 10:36 PM
Quick question AutoXMan MKIII Supra 12 09-30-2005 06:40 AM
