Old 03-29-2008, 10:05 PM   #11
3.0trd
3.0trd is on a distinguished road
I talked to Branden at horsepowerfreaks, and he told me they were 84 stock, so I went with that. 86 is a very common size cause lots of people bore the block when they rebuild them. I did have the head machined, but with the engine in the car, kinda hard to have that machined... I'll just do the best I can with a piece of machined steel and some good sand paper.
3.0trd is offline   Reply With Quote
Old 03-30-2008, 01:16 AM   #12
suprasath
suprasath is on a distinguished road
thanx for the info about the bore size. im in the same situation as you are about the head gasket. i pulled out my head cost me 400$ to machine and 3angle valve job. my block looks good and the pistons are like gold inside no ridge, so i decided to leave the block and just clean it. but im not sure if the metal head gasket will seal any small scratches.bc when you mahcine it you get back a smooth finish then itll seal. so i ddint want to risk it so im going with copper head gasket.if you have any advice let me knw.
suprasath is offline   Reply With Quote
Old 03-30-2008, 01:23 AM   #13
mkiiisupra
you want a mirror finish for a metal head gasket
1990 Toyota Supra Turbo A/T
Old 03-30-2008, 01:24 AM   #14
suprasath
what about copper head gasket does it have to be mirror. and is it reliable?
Old 03-30-2008, 01:45 AM   #15
supraflymk3
supraflymk3 is on a distinguished road
Default non turbo engine
what if i turbo my engine but the stock engine has no turbo? will it mess up my engine??
supraflymk3 is offline   Reply With Quote
Old 03-30-2008, 01:48 AM   #16
suprasath
if you do it safe it wouldnt. but you cant pound it like a turbo engine. u need turbo inectors,lower compression, good fuel at all times.i would just go with the turbo motor to be safe and lose money at the end.
Old 03-30-2008, 01:49 AM   #17
supraflymk3
alright yeah i think i'll probably just swap engines
Old 03-30-2008, 02:20 AM   #18
mkiiisupra
dont know of anyone tht went the route with a copper gasket, search around and see if ya can find ne info on it
hks head gasket suprabahamut MKIII Supra 8 09-01-2007 04:28 AM
head gasket suprabahamut Non-Generation Specific Questions 1 05-04-2007 04:13 AM
gasket help hangsupra MKIII Supra 14 01-28-2007 05:35 PM
