Old 03-16-2008, 12:51 AM   #1
whitequasimodo
whitequasimodo's Avatar
whitequasimodo is on a distinguished road
Default oil gauge
HI it’s been long time since I was on. I just got down putting a new engine in my 88 supra, and also put a new stack turbo in. I had a few questions for the surpa pros.
For the oil gauge on start for me it stays in the middle bar between the big gaps, now when I let it warm up it sits just under the 40 mark.
Now my questions to you all is when at idle were the oil gauge supposed to read and when under boost "doing 80 or so" what should it read?
thanks.
ppl in arizona hit me up. i would like to ask you all questions on what i should do next and always looking for ppl that know every about the the mkiii. "make sure i dont fuck shit up :P"
whitequasimodo is offline   Reply With Quote
Old 03-16-2008, 01:38 AM   #2
mkiiisupra
MK3 TSRM On-Line
1990 Toyota Supra Turbo A/T
Old 03-16-2008, 04:12 PM   #3
whitequasimodo
Originally Posted by mkiiisupra View Post
does the oil pressure ever get to the 80 or 120 mark?
Old 03-17-2008, 03:04 PM   #4
whitequasimodo
i cant find out whats the pressure is supposed to be at.
Old 03-17-2008, 05:50 PM   #5
twerb089
twerb089's Avatar
twerb089 is on a distinguished road
when the car is cold oil pressure should be around 40psi maybe a little bit higher.. and at idle it should be around 10-20 psi depending on the viscosity of the oil.. and if your doing 80 on the freeway oil should be close to 40
1989 supra turbo automatic soon to become a manual
K&N, megan dp, gutted cat, 2 1/2" magnaflow cat back
NA intake cam, shimmed actuator
no A/C or P/S, therefore no ac condensor, compressor and no ps pump or resivior.
gutted interior, 4 tweeters, 2 kicker 12"s powered by an MTX 400W 350rms and an audiobahn 400W 300rms
twerb089 is offline   Reply With Quote
Old 03-18-2008, 03:10 AM   #6
mkiiisupra
srry couldnt help you more than that white, my gauge does not work.... lol sits below zero unless im about to start the car then it jumps up slightly to just below the 0
Old 03-26-2008, 02:30 AM   #7
whitequasimodo
thanks man that helps a lot.
now i dont have to think every min. that maybe my top end might be deprived of oil.
Petrol Gauge Sender Supra Mk3 supra mk3 brunei MKIII Supra 0 02-17-2008 04:14 PM
Gauge cluster dcrusupra MKIII Supra 2 11-16-2005 11:55 PM
