Old 03-14-2008, 02:46 AM   #1
Micahwc
Micahwc's Avatar
Micahwc is on a distinguished road
Default Supra wont start
Hey guys,
I bought an 87 Turbo recently. It drove great for about two weeks. I parked it because I didn't have a license plate for it. The next day I installed the license plate and tried to start it. It wouldn't start.
It cranks but doesn't start. I can smell gas when I try to start it. I've looked to see if everything is connected, as far as I can tell everything is good. Any suggestions?
Thanks ahead of time.
-Micahwc
Micahwc is offline   Reply With Quote
Old 03-14-2008, 05:57 AM   #2
btwilson86
Super Moderator
btwilson86's Avatar
I don't think you can get any CEL codes since it won't start... You said you smell gas, so I would think it would have to do with a lack of spark. Check 15 Amp EFI fuse in fuse block under hood is in good shape... Since you said you just got it, you should probably give it a tune-up (which might in turn help fix your problem). Do some simple stuff like replace the spark plug wires and plugs, things like that. You might also want to check to make sure your coil packs are properly grounded.
Hope some of this helps, I'm sure some people more knowledgeable on Turbo Supras will chime in here soon.
87 Supra won't start RNEMESiS42 MKIII Supra 3 06-25-2011 06:30 PM
Supra won't start cmnetworx MKII Supra 2 07-31-2006 10:55 PM
87 Supra 7M-GTE/AT Engine cranks over but doesnt start... Supra-Boy MKIII Supra 7 03-15-2006 11:38 PM
supra wont start tex1116 MKIII Supra 2 10-21-2005 12:54 AM
