Old 02-24-2008, 07:49 PM   #1
Benesesso
Benesesso's Avatar
Benesesso is on a distinguished road
Default Easy Way to Change Air Filter
Has anyone figured out a simple way to change the stock air filter on a turbo? Seems the only way is to disconnect all the hoses starting at the turbo inlet, and work toward the front. Too bad it can't be done by removing one simple wingnut.
"You see, wire telegraph is like a very long cat. You pull his tail in New York and his head is meowing in Los Angeles. Do you understand this? Radio operates the same way: You send signals here, they receive them there. The only difference is there is no cat." A. Einstein
1988 and 1990 Turbo Supras
Benesesso is offline   Reply With Quote
Old 02-25-2008, 06:12 AM   #2
ravenmaster
ravenmaster's Avatar
LOL yeah thats pretty much the only way to do it. On the N/A's its pretty simlple just pop and pull. turbo, not so much.Thats why I just moved mine to a CAI (Cold Air Intake) the day I bought it, that and the FMS (Fuel Management System) were the best investments I have ever made for either of my supras.
1988 Toyota Supra Turbo Targa
Old 02-25-2008, 04:09 PM   #3
j3pz
can always buy a aftermarket filter and adaptor, then you dont need to worry about replacing the filter
Old 02-25-2008, 08:02 PM   #4
Benesesso
Benesesso's Avatar
Thanks for the replies. The stock setup seems to be a cold air intake, because the front plastic filter assembly picks up air from in front of the hot engine compartment. What aftermarket setup would replace that? Is a K&N unit easier to clean?
Old 02-28-2008, 07:26 PM   #5
ravenmaster
yes, it is easir, basically just a pull on and put on situation, however I would suggest if your going to put the K&N on is find a heat shield as putting on the K&N will pull the air filter into the engine compartment. You can actually make a heat shield but they are easy to find just google it. K&N doesnt make a full CAI intake for our cars, I had to actually go custom on mine. Went and had a pipe made that goes to just before where the stock air filter connects to the hole into the bumper and then put the K&N inside of the bumper, good air flow and protects it from water, rain etc.
Old 03-04-2008, 03:46 PM   #6
Benesesso
Benesesso's Avatar
Thanks. I guess I'll just take the time and replace the stock filter. I'm not about to give up the cold air for a K&N. Hope I don't break the big accordian tube---.
Old 03-04-2008, 03:51 PM   #7
ravenmaster
Ill post a pic when I get home but the way i described doing it is a pretty common mode and is considered a cold air.....
Old 03-04-2008, 04:00 PM   #8
ravenmaster
This is retty much what I did:
www.SUPRAS.com - Member's Section
I didnt use friggin duct tape but he describes the process very well.
Product Review: AEM Dry Flow Filter 3" by 5" mkiiisupra Shops & Part Reviews 4 01-15-2010 02:15 AM
Adventures in oil change land. SephyraTigre MKIII Supra 9 06-15-2008 10:02 PM
K&N Air Filter D_Train MKIII Supra 6 01-04-2008 07:27 PM
Auto Trans Oil Change Made Easy mrnickleye MKIII FAQ 4 02-25-2007 09:53 PM
Noob question, how do i change the filter? Ahmad88 Non-Generation Specific Questions 4 06-21-2006 05:23 PM
