Old 02-24-2008, 06:38 PM   #1
mkiiisupra
Default Oil leak near CPS
Any ideas on how to stop this leak? Don't know much about this sort of thing and any insight would be appreciated it.
I would guess its due to a bad seal on the inside of the engine. Also after i drive her and she has been sitting there awhile ill pull off after she has had time to warm up and i will see slight smoking coming from this section as well.
I think thats just the oil burning off but would like to know for sure
1990 Toyota Supra Turbo A/T
Old 02-24-2008, 07:41 PM   #2
Bill UK
AEM EMS
Bill UK's Avatar
A very common problem, the O ring needs replacing on the shaft of the CPS. Toyota O ring part # 90099-14018. You will need to remove the CPS unit, Instructions HERE
Old 02-24-2008, 08:22 PM   #3
Bill UK
AEM EMS
Bill UK's Avatar
Just a few extra notes:
The power steering reservoir doesn’t need to be removed completely, just remove the bracket fixing bolts and pull it to one side to give access to removing the CPS unit. Once the unit is removed the O-ring just slides over the gear at the end, no need to disassemble the unit in any way.
Unfortunately you will need to remove the rad top hose to remove the cam covers and the small coolant hose near the CPS. What is important before removing the CPS is that the crankshaft is at top dead centre and the cam timing pulley’s are lined up with their markings on the rear cam cover. You can do this by looking through the oil filler hole and at the position of the cam, but I prefer to remove the cam cover just to make sure.
When refitting the unit make sure you line up the hole and the grove as stated in the instruction. One problem I did find is when you inset the CPS the gear engages with the gear on the camshaft which causes the CPS shaft to move, this is why you will need to check the timing when you have finished.
Old 02-24-2008, 08:35 PM   #4
mkiiisupra
Wow. thanks for your help
Looks like i will need a new tool, i dont think i have anything capable of moving the crank erm
Old 02-24-2008, 08:51 PM   #5
Bill UK
AEM EMS
Bill UK's Avatar
No special tool required, just a socket spanner to turn over the engine using the crankshaft bolt. (turn clockwise) Not sure of the size around about 18 -22 at a guess.
Old 02-24-2008, 09:00 PM   #6
mkiiisupra
Do you have to loosen the bolt to rotate the crank or will it just turn with a socket wrench on it?
Old 02-24-2008, 09:03 PM   #7
Bill UK
AEM EMS
Bill UK's Avatar
Some more info on timing here
http://www.cygnusx1.net/supra/Library/TSRM/MK3/manual.aspx?S=IG&P=20
http://www.cygnusx1.net/supra/Library/TSRM/MK3/manual.aspx?S=EM&P=23
Old 02-24-2008, 09:04 PM   #8
mkiiisupra
yes, i have recently redone my timing it was set at 5 lol now its at 12
Got the timing light and everything
Old 02-24-2008, 09:12 PM   #9
Bill UK
AEM EMS
Bill UK's Avatar
Just locate the socket onto crankshaft pulley bolt and turn it clockwise, as if you where doing it up, don’t worry the bolt is tightened at a very high torque setting, something like 80 +psi off the top of my head I think.
Correction 195 pounds per sq foot
Old 02-25-2008, 01:19 AM   #10
mkiiisupra
ahhh ok good, ill have to try that next couple days i have off, thank you alot for you help
Heater Union (Coolant Leak) slader99 MKIII Supra 11 12-28-2009 12:29 AM
Oil Leak. supramacist MKIII Supra 0 05-01-2008 01:18 AM
Coolant Leak bossman MKIII Supra 2 04-12-2008 09:31 PM
Oil Leak Question kidsusukigsxr Non-Generation Specific Questions 2 06-26-2007 03:17 PM
gas tank leak burton51m MKIII Supra 14 11-24-2006 06:16 PM
