Old 02-20-2008, 07:42 PM   #1
suprasabre
suprasabre's Avatar
suprasabre is on a distinguished road
Default Another BHG
After putting in a "Low mileage" JDM engine and tranny over a year ago in my 89 Supra N/A, then spending a good part of this last year working out all the issues to get where I could drive it, I have been driving it back and worth to work over the last couple of months. During this time I kept seeing signs of a BHG, but was not totally convinced until last night after driving the hour and a half home.
I had replaced the thermostat housing seal on Saturday and so when I saw the radiator down Monday morning, I wasn't that concerned and I just topped off the radiator. But when I got home last night, the overflow bottle was overflowing and when I checked the radiator, later after it had cooled down, the coolant level was down a good inch, again.
This is not a first time for me, I had to replace an 87 Head gasket back in 2001. That car ran for about 40k and even survived my sons driving for a couple of years.
So I'm going to pick up the parts and start replacing the Head Gasket over the next couple of months. (I have a motorcycle and truck for transportation) While I'm at it, I'll get ARP studs and silicon hoses for it. Since it will be nice and clean, might as well make it look good too!
I will not be putting a metal head gasket in it, but I was wondering is any one brand of head gasket recommended for a good replacement? And if so, how much better then just getting a Toyota head gasket?
Another question I have, has anyone have experience with any of the head gasket kits off ebay? Good or bad?
Thanks!
Bob
89 Supra N/A
05 Honda ST1300 (motorcycle)
suprasabre is offline   Reply With Quote
Old 02-20-2008, 10:54 PM   #2
supramacist
supramacist's Avatar
HKS Stopper MHG.
ARP head studs.
And you can beat on it till the cows come home.
You're going to need some machine work as well.
Old 02-20-2008, 11:27 PM   #3
suprasabre
suprasabre's Avatar
Originally Posted by supramacist View Post
HKS Stopper MHG.
ARP head studs.
I plan on taking the head in and have it machined, but not the block if I can help it. Since I don't plan on racing the car (except when trying to get on the freeway), I think a metal head gasket would be overkill and too expensive since you need the block machined as well.
ARP Studs are at the top of the list though.
Bob
89 Supra N/A
Old 02-20-2008, 11:49 PM   #4
supramacist
You can get by with the block not beeing machined.
If you resurface it by hand.
The mhg price is nothing compared to real fix instead of a band aid.
Good Luck
Old 02-21-2008, 01:20 AM   #5
ddmcse
ddmcse's Avatar
Cool
if you're not boosting you are fine with a regular gasket and it will seal better than a metal at this point
300+ RW HP Dyno run,
Blown HeadGasket info
My Supra KiXGaS
Old 02-21-2008, 02:10 AM   #6
supramacist
Right on.
I hear of guys using the reman's gasket from the dealership with arp hardware..
Felpro, I have never heard anything good about.
Cometic is mixed at 50/50.
Have you thought of a "beaded" gasket?
I personally would still look at what HKS has to offer.
Hope this helps.
Old 02-21-2008, 06:51 PM   #7
suprasabre
suprasabre's Avatar
Okay, to use a metal head gasket, what can I do to the block to "clean it up enough" so a "bead" type gasket would work?
Also, I see the different thicknesses of the gaskets, how do I know (other then a stock 1.2mm) which to use? I'm assuming of course that this engine has never had the head gasket replaced.
From HSK Website:
11116-153195TOYOTA Supra 1986.5-1992 ; Engine Code: 7MG(T)EBead86-1.2$110.00
What other things do I need to know about the metal gaskets that hasn't been said so far? I've been reading the different websites on it, but are there some that go into details about cleaning up the block?
I figure, if I'm going to this much trouble, doing it right would be nice.
And of course, thanks for the info so far!
Bob
89 Supra N/A
Old 02-21-2008, 07:50 PM   #8
h8z2luze
h8z2luze's Avatar
h8z2luze is on a distinguished road
I just used a sanding block with very fine grit wet/dry sand paper after cleaning all the gasket material off. I used ARP Bolts and i was fine.... till i burned out a rod bearing but thats not the problem of the gasket or bolts lol. I used a regualr gasket the first time drove it maybe 100 miles and it blew again so ya the metal gasket is worth it by far.
1989 Supra 7MGE MK3 5-speed project...
http://www.cardomain.com/ride/2385505
h8z2luze is offline   Reply With Quote
Old 02-21-2008, 07:57 PM   #9
supramacist
To find out the thickness of gasket you need.
You need to know how much the machinist removed from the head.
Go to: Performance Parts Aftermarket and Racing
Get the # when the tone asks for an extension..., dial 103.
You'll be speaking to dave. He can get you the gasket that you need.
With the info from the machinist, he'll go to a chart that will tell him
the thickness required.
I would seriously go beaded.
A MACHINED block. Not just a 2x4 and if you didn't sand on it for days.
You didn't do any good nor did you hurt anything. So long as you cleaned it out very very well.
You'll also be wanting arp studs or bolts.
You're going to need a volt meter and a torque wrench.
All of the seals you destroy during the tear down, you want to order them as soon as you have enough to constitute a real parts order.
I used a 2.mm stopper HKS. It's bloody beautiful.
You'll feel much better once you press the head down and retorque
the head to 80lbs. You'll know the difference and quick.
DO it right. Do it once.
research research research.
Old 02-21-2008, 08:04 PM   #10
h8z2luze
h8z2luze's Avatar
so is it not worth it to buy the beaded 1.2mm gasket??? Is the stopper the only way to go?
