Old 02-09-2008, 11:57 PM   #1
tak2099
tak2099's Avatar
tak2099 is on a distinguished road
Default manual boost controller
Ok, so i installed a manual boost controller a while ago(and i have even tried installing it several different ways after friends suggested) and all it seems to do is eliminate the actuator, so the turbo just boosts all the way untill it hits fuel cut. I have even tried two different styles of boost controllers. can anyone possibly tell me exatly how youre supposed to hook it up, maybe some pictures would help as well.
tak2099 is offline   Reply With Quote
Old 02-10-2008, 04:44 PM   #2
mkiiisupra
there is a vacuum line the goes to the accuator just install the boost controller there
1990 Toyota Supra Turbo A/T
Old 02-10-2008, 10:03 PM   #3
Supra2NR
Supra2NR's Avatar
tap the line that goes to the turbo and the wastegate actuator,
makes sure the boot controller is pointed and hooked up the right way
if it still hits fuel cut, u need to adjust ur boost controller
Old 02-11-2008, 01:12 AM   #4
tak2099
tak2099's Avatar
i finally figured it out, and the boost controller does not work if you tap it to the line from turbo, you have to cap off the line that comes from the turbo, and hook it into a vacuum line from after the throttle body. or at least thats the only thing that worked for me.
Old 11-21-2009, 11:10 PM   #5
dupra87
dupra87 is on a distinguished road
Default ???????????
im having the same problem. can u be more lame man terms for me please not understanding what u mean
dupra87 is offline   Reply With Quote
Old 11-23-2009, 11:47 PM   #6
Here's a DIY on it making boost controllers with a couple weak diagrams on vacuum routing:
http://www.gusmahon.org/html/boostcontrol.htm
You can source vacuum from either the manifold or the turbo, sourcing from the turbo is the safer setup when you're not running a boost controller... it reduces surge, both heat and temp (this is of course not relevant when running any sort of boost controller).
Manual Boost Controller and Turbo timmer question ethan12510 MKIII Supra 5 02-20-2008 10:54 PM
manual boost controller!!!!!!! justin1642 MKIII Supra 6 01-16-2007 10:01 PM
ANY ONE EVERY USE A Apexi Boost Controller donutking MKIII Supra 1 10-07-2005 01:58 PM
