Old 02-06-2008, 01:11 AM   #1
mirage83
Default Grungy gas tank on my '88
Already drained and dropped it, pulled what was once a fuel pump out, but there's all sorts of nastiness in the bottom of the tank. What's the best way everyone's found to clean the grime and debris out of your gas tank when restoring your Supra's? Thanks for any and all advice.
Old 02-06-2008, 02:38 AM   #2
CyFi6
im no expert, but how about use gasoline to clean it?
Old 02-06-2008, 02:52 AM   #3
linuxgurupodboy
linuxgurupodboy's Avatar
linuxgurupodboy is on a distinguished road
If gasoline was in it and it had grime, I would doubt alot that gasoline would get rid of it. You need to use something more pure like thinners, try and not get the thinners on any plastic or paint. If that doesn't work you can cut the tank in half and use it as a bird bath.
1990 3.0Ltr GT Turbo @8psi Manual (Converted)
linuxgurupodboy is offline   Reply With Quote
Old 02-06-2008, 03:51 AM   #4
mkiiisupra
i guess there is no real way to just scrub it out huh? i still need to drop mine and see what i find lol
1990 Toyota Supra Turbo A/T
Old 02-06-2008, 05:31 AM   #5
Pretaco
I have a tank for sale, or you can take it to most radiator / fuel tank shops and they will clean it out for you.
They have special solvents, and I think some use a bead blasting type procedure.
Don't know how much it will cost though.
Ray.
Currently Running Good
Old 02-06-2008, 03:14 PM   #6
f00g00
Yes a radiator shop can boil the tank for you.
Old 02-06-2008, 10:12 PM   #7
mirage83
Default Thanks for the feedback everyone.
After asking around town found a shop that can clean and reseal it if necessary. Won't be cheap (about $100 for the reseal), but that's still a LOT better than the cost of a new one.
"I have a tank for sale,"
What are you asking for it, and do you have any idea what shipping for something that size would be from your location to N. Georgia?
Old 02-06-2008, 10:22 PM   #8
Pretaco
I will sell it for $50 + shipping, ground would be about $30, so not much cheaper.
Ray
Old 02-09-2008, 04:42 AM   #9
supramacist
supramacist's Avatar
That's a good price.
Someone should buy it for the hell of it at that price.
Old 02-09-2008, 05:32 AM   #10
Pretaco
Some one should buy it!
no pump and no sender.
Slow Bubbles Into The Resevoir Tank Drag0na5h MKIII Supra 2 03-18-2008 05:37 PM
Overflow Tank D_Train MKIII Supra 1 03-21-2007 02:52 AM
gas tank leak burton51m MKIII Supra 14 11-24-2006 06:16 PM
WAter not going back to raditor from recovery tank Help Jeff_5_7 MKIII Supra 12 09-15-2006 03:49 AM
WAter not going back to raditor from recovery tank Help Jeff_5_7 MKIII Supra 0 09-07-2006 02:05 AM
