Old 06-21-2005, 05:24 AM   #1
boostedsuby
boostedsuby is on a distinguished road
I have another post about dist wires, but here's another question: When the engine was running (before my bro-in-law sold it to me) there was a knocking sound coming from the valve cover area. My brother swears its a rod, but the noise is definitely up high. Does anyone familiar with Supras know what I might check before resorting to yanking the engine and checking the bottom end?? Thanks again.
boostedsuby is offline   Reply With Quote
Old 06-21-2005, 06:20 AM   #2
Is it a light tapping sound? = valve adjust......
Piston slapping the walls ???
Rod knocks, (bearings) sometimes can be made to sound up by lightly playing with the throttle. Barely increase and decrease the rpm a little bit, if it gives a rattle sound, it could be a rod bearing. Pull spark plug wires, one at a time, and ground them. If the sound stops on a certain cylinder, its that one bad.
Old 06-21-2005, 03:18 PM   #3
boostedsuby
It doesnt sound like piston slap. We did pull a plug wire (before the wire chopping) and found the source. The fact that the noise goes away then is the reason my brother thinks its a rod. Im unconvinced. The sound is up high. I put my ear next to the valve cover (drivers side) and can distinctly hear it there. Nowhere else. Does anyone have any guidance on adjusting valves on these cars? I didnt know lash could be adjusted on them. Im trying to avoid buying a manual until I know whether to keep it or not. Call me cheap....Anyway, thanks.
Old 06-21-2005, 03:23 PM   #4
there are manuals online
http://www.cygnusx1.net/supra/library/TSRM/index.html
Old 06-22-2005, 05:44 PM   #5
KingDiamond
Does it make the noise constantly no matter what, if it doesn't do it all the time, does it do it under load, when your actually driving the car. Does it do it if you just raise the rpms up from under the hood?
Old 06-24-2005, 04:10 AM   #6
boostedsuby
The knock is always present. At idle and revving. It does go away when the plug wire is removed and only then. It did quit briefly when the previous owner had it for about 2 minutes when he started it, but came back. Thanks.
engine knocking red_armie_soviet Non-Generation Specific Questions 1 09-28-2007 10:06 PM
Potentially buying 1987 Supra Turbo with knocking noise saturnvii7 MKIII Supra 3 04-24-2007 05:59 PM
Terrible noise from the Drivebelt area 94TT MKIV Supra 2 12-04-2006 12:29 PM
HELP! My engine just started a weird noise... idoke MKIII Supra 12 10-05-2006 05:06 PM
help on knock knock noise Guest MKII Supra 3 05-31-2005 07:41 PM
