Old 01-27-2008, 11:48 PM   #1
supra90
supra90 is on a distinguished road
Default tranny
how do i know which tranny do i have on my 7mgte and can i use it with a 1jz
supra90 is offline   Reply With Quote
Old 01-28-2008, 12:42 AM   #2
Pretaco
To figure out what type of tranny you have, follow these simple steps:
1. Walk out to your car.
2. Unlock and open the door.
3. Look at the shifter, it should be located in between the two front seats, sticking up out of a bunch of plastic and vinyl trim pieces.
4. Read the lettering on and near the shifter: If it says 1-2-3-4-5-R, on the top of the shifter it is a MANUAL. If it says P-R-N-D-2-1 to the left of the shifter, it is an AUTOMATIC.
5. You can also tell by counting the pedals, checking for a dipstick, or looking at it.
If you have a manual, its the r154, automatic is a540e.
A 1jz bellhousing is required to use the r154 with the 1jz or 2jz engine.
Ray.
Currently Running Good
Old 01-28-2008, 02:14 AM   #3
mkiiisupra
Ray.
hahaahahahahahahaha, sorry had to laugh your post made me smile
1990 Toyota Supra Turbo A/T
Old 01-28-2008, 04:01 AM   #4
supramacist
supramacist's Avatar
I liked it also but if it would have been I that said you cats would have flamed me so I just let it slide.
That's right up there with going to a supra forum to ask about your mitsubishi or some shite.
Old 01-28-2008, 06:12 AM   #5
oowee623
oowee623's Avatar
If you have a manual, its the r154, automatic is a340e.
fixed.
7mge-auto a340e/manual w58
7mgte-auto a340e/manual r154
1jz bellhousing needed for r154 or an mk4 2jzge bellhousing for w58 on a 1jz or 2jz
89 white package twin turbo
Originally Posted by supradaddy0803
the results of your work will be very nice when you push the gas and hold on for dear life.
Old 01-28-2008, 02:50 PM   #6
Pretaco
OOPS!
a540e is newer, a340e is correct.
Thanks for clearing that up.
Ray.
p.s. why would you want a w58 on a 2jz? That seems like it would be pretty unreliable. From what I've heard the w58 won't even hold up to the 7mgte.
Old 01-28-2008, 08:32 PM   #7
supramacist
The w58 is a fine tranny so long as you respect the 400hp rating.
The r154 is supposed to be rated at 1000hp.
What kind of supra are you really building???
Old 01-28-2008, 10:36 PM   #8
oowee623
oowee623's Avatar
w58 came with manual 2jzge
Old 01-29-2008, 02:21 AM   #9
supramacist
The w58 is not a 6 speed tranny.
Old 01-29-2008, 02:50 AM   #10
mkiiisupra
If i had the money to blow i think i would stick a 6 speed automatic transmission in, however no idea how i would ever get it to work... Any ideas? ZF Transmission
Or perhaps the 8 speed? lol ZF Develops New 8 Speed Automatic Transmission - HorsePowerSports
Or a CVT type transmission
Tranny ? Need Info! SilverBullet05 Non-Generation Specific Questions 0 07-07-2008 09:45 PM
Auto Tranny Issues? jbjorndal MKIII Supra 3 03-14-2008 09:31 AM
Mk2 Tranny Conversion panda-supra MKII Supra 5 02-28-2006 06:04 AM
