Old 01-24-2008, 12:27 AM   #1
mkiiisupra
Default On my way to work this afternoon....
I go to crank my vehicle and it is completly dead... battery is so dead that i couldnt even jump start it lol.... Brand new battery...
I hope i just left a door a little ajar and the interior lights ran down the battery it was sitting there for a few days.
I know the car won't let you leave the headlights on, not sure about the interior lights though, do they turn off after a certain amount of time??
If so then my alternator is probably to blame...
1990 Toyota Supra Turbo A/T
Old 01-24-2008, 04:22 AM   #2
mkiiisupra
Anyone know if interior lights stay on if door is slightly ajar?
Try'n to determine if its a bad alternator or if i just drained the battery
Old 01-24-2008, 10:32 AM   #3
dcrusupra
dcrusupra's Avatar
Sounds like a defective battery. Put a charge on it and see if it starts.
New Rebuild
My CarDomain
Old 01-24-2008, 10:33 AM   #4
mkiiisupra
will try to charge it once i get home, if thats the case least it has a warranty
Old 01-25-2008, 05:17 PM   #5
mkiiisupra
well charged the battery for 5 hours and car started fine, we will see how long it lasts, if it dies again ill take the battery back to the store and exchange it out
Old 01-25-2008, 07:01 PM   #6
indytrucks
indytrucks is on a distinguished road
I'm iterested in this too. I know its not my battery as I've had 2 others drain on me. What else could be causing a fast drain?
indytrucks is offline   Reply With Quote
Old 01-25-2008, 07:26 PM   #7
Pretaco
Pretaco is on a distinguished road
Have you tested your alternator yet?
Do you have any aftermaket parts connected that could be draining your battery?
Do you have a ammeter to check your battery draw when the vehicle is off?
I love answering a question with three more.
Ray.
'88 Supra Targa 5 speed w/ '90 7M-GTE
Currently Running Good
For Sale: Light blue body parts, Blue interior parts all from '90 supra targa turbo manual.
Also for sale: R154 trans, brake pedal, master cylinder, booster, abs actuator, sensors, abs ecu, driveshaft, 3.90 lsd rear end, radiator, wiring, speedo cable, 8 saw blade wheels, '88 ecu, relays, cruise control actuator (bad cable), empty fuel tank, etc....
Pretaco is offline   Reply With Quote
Old 01-25-2008, 08:19 PM   #8
f00g00
Lights will stay on if the door is slightly open.
Old 01-28-2008, 06:41 PM   #9
zambini
zambini is on a distinguished road
yeah when i had my car in the garage fixing the rear quarter, i would always end up leaving the door open a little bit, and if it's not completely latched, the interior light will drain your battery.. went to start it and the battery was so dead the car wouldnt even ding when i put the key in haha. had to charge the battery like 3 or 4 times because of this
zambini is offline   Reply With Quote
Headlights only work on High Beam - is it a fuse? t4yl0r10 Non-Generation Specific Questions 8 01-18-2008 03:56 PM
auto to manual swap completed!!! but speedo doesnt work oowee623 MKIII Supra 10 08-20-2007 12:21 AM
N20 and HeAd WoRk Supra_87_mk3 Non-Generation Specific Questions 4 05-25-2007 03:09 PM
Dash lights Don't Work supra67 Non-Generation Specific Questions 4 09-05-2006 04:58 AM
Dash lights Don't Work!! supra67 MKIII Supra 0 08-10-2006 01:11 AM
