Old 01-23-2008, 04:24 PM   #2
Pretaco
Pretaco is on a distinguished road
Does it even try to start, sputter or anything.
Usually if one or two injectors are bad, the engine will still start, just run crappy. Check for fuel pressure, spark, timing, compression, and if all that is good then look at the injectors.
'88 Supra Targa 5 speed w/ '90 7M-GTE
Currently Running Good
For Sale: Light blue body parts, Blue interior parts all from '90 supra targa turbo manual.
Also for sale: R154 trans, brake pedal, master cylinder, booster, abs actuator, sensors, abs ecu, driveshaft, 3.90 lsd rear end, radiator, wiring, speedo cable, 8 saw blade wheels, '88 ecu, relays, cruise control actuator (bad cable), empty fuel tank, etc....
Pretaco is offline   Reply With Quote
Fuel injectors redneck ricer MKIII Supra 0 06-15-2007 02:31 AM
Fuel injectors Biku Off Topic Forum 7 07-23-2005 04:36 AM
