Old 01-14-2008, 04:51 PM   #1
binxy69
binxy69 is on a distinguished road
Default Can anyone help? Cleaned out air intake, now keeps dieing.
Hi, I just purchased a 1991 Supra mk3 manual turbo. Newly reconditioned engine, running sweet as.
I thought I'd give the K&N filter that was on the Air Flow Meter a bit of a clean and clean out the throttle butterfly as in my oppinion it felt a bit gummed up.
After taking everything off, and cleaning it all up i proceded to put it all bk together and went to start it.
It started up fine, and idled perfectly. I then went to throttle up, and it just died. When i tried to start it again it started fine again, and throttled fine up to 2500rpm then sluttered and died. I also noticed the engine fault light was on. Now everytim I start it the fault light comes on.
I tried resetting the ECU by disconnecting the battery, when I start it the ENgine fault light isn't on, but then it just dies instantly. On trying to start it again the fault light comes straight on, and it'll rev up to 2500rpm again.
Something tells me its going into a "safe mode", what could I of done. I thought I'd managed to damage the air flow meter, but all the voltages are fine and a good signal coming down the cable.
Has anyone got any suggestions?
Many thanks, Jim
binxy69 is offline   Reply With Quote
Old 01-14-2008, 07:49 PM   #2
abhattan
abhattan's Avatar
Did you try to read the code from the computer? Try that first. It should point you in the right direction.
'91 Turbo Targa 5 Spd.
'87 Corolla GT-S 5 Spd
'91 Accord Daily Driver 5 Spd
Old 01-14-2008, 09:03 PM   #3
binxy69
Cheers mate, I've just done it, it came up with 31, which is a mass airflow meter, wiring or connector problem.
So obviously I've managed to either damage the AFM, or the wiring is up the creek. Whja I need to know now, and I'm having problems, is what voltages should be coming up the wire to the AFM to therfore diagnose whether the wiring is up the creek. If it is fine, i think I may need a new afm :-(
Old 01-14-2008, 09:07 PM   #4
mkiiisupra
i have heard a few times that the K & N filters can damage the AFMs on our cars, since it is a oiled filter
1990 Toyota Supra Turbo A/T
Old 01-14-2008, 09:09 PM   #5
binxy69
Ow bollox. Thats exactly what I did. Since K&N's are supposed to be oiled thats what I did after I cleaned it.
Is that the end 4 my AFM then, any ideas?
Old 01-14-2008, 09:10 PM   #6
mkiiisupra
not sure, if it just has oil gunk in it, and ur sure its already shot i would suggest taking it apart and cleaning it out, taht may fix it... but personally before i mess with something like that i make sure it is already busted lol
Old 01-14-2008, 09:13 PM   #7
binxy69
I've had the AFM apart already, thought it looked a bit damp in the little holes that allow the pressure reading to be taken. I bet that was air filter oil. I wonder if I blast it out with carb cleaner and leave it on the boiler overnight to dry out it might do a miraculus recovery.
On another note, wheres the cheapest place to get an AFM from?
1. I'm a student at brighton uni so money isn't something in huge supply
2. I dunno if it even broken yet lol
