Old 01-09-2008, 07:48 AM   #1
SCRAMJET
SCRAMJET's Avatar
Default low idle
How do you increase the idle speed in a 1jz?
1jz scramjet mkiii
Old 02-17-2009, 01:00 PM   #2
RED1JZ
RED1JZ is on a distinguished road
sounds like ur ICV man i had the same problem its located at the back of the plenum manifold on the left just rip the pipes out and block them up including the vacums then just adjust ur thottle body lever screws till u get it to the right rpm bout 650 is good mabey 750 make sure u adjust it when ur car is at cold start...
88 Supra
R154 Manual
1JZ Converstion Intercooled
Apexi Rampod
Hks TurboTimer
Blitz Nur Spec Zorst 3inch with hiflow cat to 4 inch cannon
Greddy Stage2 Elec Boost Controller 12psi...
Nxr 235/35/18s 245 on the back
Red Respray Black Bonnet
RED1JZ is offline   Reply With Quote
won't idle 3.0trd MKIII Supra 6 06-15-2009 07:23 PM
Wastegate Idle issue... please help Subjug4tor MKIII Supra 9 05-15-2008 01:59 AM
Car doesnt like to idle in the morning XxSupra4LifexX MKIII Supra 11 12-24-2007 07:27 AM
HELP!!!!!!!.....1JZ wont idle!!!!! kuroi_tuki MKIII Supra 1 07-09-2007 12:41 PM
HELP!!!! '87 Supra idle problem Morpho MKIII Supra 0 10-03-2005 02:40 PM
