Old 08-03-2011, 11:28 PM   #21
mk2brooks
mk2brooks is on a distinguished road
hahah thats impressive.
Hey man don't get mad, that you don't have one...
1984 supra with an 7M-GTEu
mk2brooks is offline   Reply With Quote
Old 08-04-2011, 12:20 AM   #22
El Supracabras
El Supracabras's Avatar
Well, I got nothing else. Pics are proof enough. All I can say is.... cool, another mk2 with a 7m, nice. Score on a rare engine.
Old 08-04-2011, 01:01 AM   #23
yea, not mad buddy.. congrats on the rare find! Engine bay looks nice. must of put some work into it.
Old 08-04-2011, 06:14 PM   #24
mk2brooks
Thumbs up
Thanks.. I get a little mad when someone say that I don't have something in my car. When I do all the work to it..
Old 08-05-2011, 01:28 PM   #25
El Supracabras
So, uhhhh, you gonna tell us where the heck you picked up such a rare piece of a supra? You got some inside source or something? I'd love to get my claws on that ecu.
Old 08-05-2011, 11:23 PM   #26
mk2brooks
Ebay...lol..
Old 08-07-2011, 12:56 AM   #27
turbonicsperformance
ive got an A on my compressor housing also and come to think of it the engine that i took out of the car was a ge block??? i thought some idiot had just put a turbo on their 7mge and thought it would work. i guess i should have done a little more research before scrapping that block... oh well.
I thought the A was normal stamp for a st26 housing but i guess it a little different ...
gotta love finding out stuff you have is better than you thought.
I th
Old 08-07-2011, 02:14 PM   #28
El Supracabras
I th
Don't get too excited, you probably were right. The A on the housing is normal from what I have seen. My 89 has it on the compressor too. You could measure the wheel to see if it is any bigger than a regular ct26.
Old 08-07-2011, 02:45 PM   #29
MA70-3.0GT
MA70-3.0GT's Avatar
Oh good hell.... I just learned that i potentially blew a CT26 A then...
Rest is standard GTE fare tho afaik, has afm based system so guess someone just got hold of an A spec turbo... good job I didn't try a rebuild kit then
Anyone got impeller/turbine dimensions to hand?
EDIT-: further to this, having done some trawling the stock CT26 (which does have an A on the comp housing anyway) appears to have fairly even sized turbine/compressor housings externally, anyone confirm? Mine appears to be rather bigger on the compressor side...
Old 08-07-2011, 06:37 PM   #30
i've been doing alot of reading up on this and the ct-26A was an option in 89 for the regular 7mgte there was 700 of them produced and 500 sold in the u.s it has a better machined compressor housing and a 2mm larger inducer 1mm larger exducer (not sure about this pic but the ct26-A has 6 dual blades and ct26 has 5 dual blades) i think they mioght have labeled the pic wrong i count % dual blades on both wheels here
and yeah i thought that also but when i was taking out the original engine that i believe to be a turbo-A engine i found a map sensor and had no idea why there wasn't a plug for it i kept searching the diagrams for one before deciding someone just used it as an expensive vac plug
