Old 12-27-2007, 08:41 PM   #1
gomezmk
Default sensor?
I recently bought a JDM 7m-gte and noticed that on the thermostat housing cover( after the thermostat), instead of a vacuum thermo switch for the evap, there is a looks like a temp sensor 1 wire type. Whats this sensor for? Do I just remove it and not worry about it. I think the only coolant temp sensors need is for the cold start and normal coolant them sensor.
Old 12-27-2007, 11:46 PM   #2
Pretaco
Depends on the year of the motor and of the car.
Should have one two prong sensor for the ecu, one two prong for the cold start injector and one one prong for the temp gauge in the dash, unless I am forgetting something. I would either use the t-stat housing from your old engine, or swap the sender for the evap vsv.
Ray.
Currently Running Good
Old 12-28-2007, 11:38 PM   #3
mkiiisupra
You mean the three sensors on the thermostat housing?
The middle one senses the coolant temp and shuts off ur A/C if it gets too hot. You can keep it unplugd had mine that way for months
1990 Toyota Supra Turbo A/T
Old 12-29-2007, 01:43 PM   #4
Bill UK
AEM EMS
Bill UK's Avatar
The BVSV is not used on the UK models, its not uncommon to remove the BVSV and screw in a temp sender unit to use with an extra temperature gauge, which may be the case with yours.
TPS Sensor and Auto Trans btwilson86 MKIII Supra 5 02-12-2008 07:31 PM
550 injector & lexus air flow troubles o2 sensor? night-rider MKIII Supra 1 09-03-2007 08:52 AM
O2 sensor? rnoswal MKIII Supra 5 08-02-2006 01:53 AM
