Old 12-25-2007, 03:41 AM   #1
77celi
77celi is on a distinguished road
Default Cut wires
I have six cut wires I know 4 of them go to the ignitor. But I don't know what color go to what wire. My motor is 87 7mge. can some one post a pic or know what color goes where?
Thanks
Ryan
77celi is offline   Reply With Quote
Old 12-30-2007, 10:15 PM   #2
77celi
can anyone help me? Does anyone live around kennewick wa? and can I come by and look at your engine?
Old 12-30-2007, 10:23 PM   #3
mkiiisupra
Bishop's 92T Supra Page
scroll down look at links at bottom 3 diffrent angled pictures of the engine bay, maybe u can see what u looking for
1990 Toyota Supra Turbo A/T
Old 12-31-2007, 05:24 PM   #4
77celi
There is a little differnce yours is turbo mine is not.
Thanks for your help.
Old 12-31-2007, 10:23 PM   #5
Pretaco
Pretaco is on a distinguished road
What colors do you have?
Do you have the connectors, or are you going to cut the other connectors off and solder the wires together?
Get pics of what you are working with and maybe someone here can help you.
Ray.
'88 Supra Targa 5 speed w/ '90 7M-GTE
Currently Running Good
For Sale: Light blue body parts, Blue interior parts all from '90 supra targa turbo manual.
Also for sale: R154 trans, brake pedal, master cylinder, booster, abs actuator, sensors, abs ecu, driveshaft, 3.90 lsd rear end, radiator, wiring, speedo cable, 8 saw blade wheels, '88 ecu, relays, cruise control actuator (bad cable), empty fuel tank, etc....
Pretaco is offline   Reply With Quote
Old 01-01-2008, 05:23 AM   #6
supramacist
supramacist's Avatar
The parts guy at your local dealership has a phone on his desk for a reason.
Reah out and touch someone.
He'll tell you so You'll buy parts and when you do show up to purchase he'll
know you and won't just rip you.
These guys at the dealership need only to be under the illusion that you are restoring or rebuilding one of these cars and you just get the discount.
You should use as many toyota parts as possible. It helps when you need a new fan shroud. That hunka plastique costs 250 bucks. You can get it for 225$. If they know you. Some parts you just get raped on no matter where you buy them so spend the extra 10 / 12 bucks and go toyota stock oem.
This doesn't apply to head gaskets. I don't care what anyone says. I wouldn't trust a toyota oem replacement head gasket.
Old 01-03-2008, 01:01 AM   #7
77celi
Old 01-03-2008, 01:03 AM   #8
77celi
I don't know why the pics did not show but this is where they are: classic-celica.com » Dustin77
Old 01-05-2008, 11:28 PM   #9
77celi
Can anyone help me please?
Ignition Wires SideWinderGX MKIII Supra 10 07-19-2007 08:44 PM
Spark plugs & WIRES HEMAN MKIII Supra 2 11-03-2006 05:31 AM
Ignition write up.. midwestmk2 MKII Supra 0 06-11-2006 02:56 AM
spark plug wires kewlcoconut MKIII Supra 2 03-19-2006 07:45 AM
loose wires 87supraturbo19 MKIII Supra 10 01-19-2006 05:51 PM
