Old 12-22-2007, 04:39 AM   #1
Boombastic
Boombastic is on a distinguished road
Default Brakes?!?
Well I have hunted around the net for a little bit trying to see if there is some kind of big brake kit for my 88 turbo. I have come up short because it seems everyone who makes a kit for supra is years 93-98 which doesn't help me out, and to boot there supra expensive like close to 2500.00 for all 4 wheels. I have since figured out a way using a toyota 4runner 4-piston caliper and a roush mustang 13" rotor cross-drilled and slotted because mustangs and supras have the same bolt pattern. In the rear I am going to put the stock 10" rotors on from the front for more surface area and am trying to locate a 2-piston caliper for that set-up. I was wondering though if I need to upgrade my master cylinder and brake booster to keep up with adiquate pressures to feed the beefier calipers all around? And if so is there a place where I can buy such a thing, or could I just go out and get a brake booster with matching master cylinder off an old truck to keep up with the needed pressures?
Boombastic is offline   Reply With Quote
Old 12-23-2007, 04:39 AM   #2
Pretaco
I don't know much about the supra brakes, but I can't imagine the 4runner ones are much bigger, at least not until 2002.
I have an '85 truck and know about the older 4runners and trucks, the master cylinder isn't any biggger. One from an fj80 should bolt up, but it has the same size bore (1"). You can get those from marlin crawler, they sell them for 4x4's. (say that 3 times fast!) They also sell calipers for 86-95 4runners if thats the correct year to fit on the MKIII.
Currently Running Good
Old 12-23-2007, 06:24 AM   #3
Boombastic
Thanks bro I definitely look into that. Cheers.
Old 12-24-2007, 12:53 AM   #4
oowee623
oowee623's Avatar
wilwood makes bbk for mk3s
89 white package twin turbo
Originally Posted by supradaddy0803
the results of your work will be very nice when you push the gas and hold on for dear life.
Old 12-24-2007, 06:05 PM   #5
Boombastic
Do you have any idea how much? Im sure it's pretty expensive
Old 12-24-2007, 09:31 PM   #6
oowee623
oowee623's Avatar
$1000+ for the front
Old 12-25-2007, 03:28 AM   #7
Boombastic
Ok well I will look into that I know a shop who deals alot of with Willwood brakes so I may be able to get a deal.
Two Issues: Front Brakes and Sporadic Vibration Chambers MKIII Supra 0 11-03-2007 04:15 PM
13 inch Wilwood MKIII front brakes ARZ Arizona Performance 0 03-16-2007 07:57 AM
Brakes 5M Vs. 7MGTE panda-supra MKII Supra 3 03-22-2006 09:07 AM
Brakes acting up maksimus54 Non-Generation Specific Questions 4 07-06-2005 11:47 PM
