Old 12-21-2007, 02:37 AM   #1
Pretaco
Default New guy, lots of questions
I just bought an '88 supra without and engine and a '90 supra with and engine, and am in the process of putting the 90 engine into the 88.
I have most of it figured out (I am a mechanic, but no experience with turbos).
My first question is: the factory waste gate is wasted. Somehow a hole has been punctured in the actuator. I figure this is a good excuse to upgrade to a 'divorced' blow off valve. What exactly do I need to buy to make this happen?
And what do I do with the factory one?
What are good cheap upgrades to do for the turbo motor?
Anyone interested in blue interior trim parts and an r154 manual trans, and light blue body parts?
I figure I will part out the rest of the '90 when I get the 88 running.
Thanks,
Ray.
Old 12-21-2007, 04:55 AM   #2
Supra2NR
Supra2NR's Avatar
well with the 90 motor came with diffrent motor mounts
you need to find motor mounts from pre89 motor
with the wastegate, you need to replace it
idk i never heard of a divorced blow off valve
jus find a used ct26 turbo and take the wastegate off of it
you cant jus use external wastegate
since you will need another manifold for them
and i think your talking about a divorced downpipe
you will need that custom-made for ya, if your using the stock manifold
or maybe sum company makes a divorced downpipe that bolts to our manifold
cheap upgrades to the motor
ranges from intake, exhaust,better ignition system
lexus maf, 550cc injectors,boost controller, to raise the boost
hardpipes for the intercooler
clean the intercooler, cuz most likely itll have oil and 20 years worth of dirt in it
i most likely missed something, but feel freeto add on
Old 12-21-2007, 07:06 AM   #3
Pretaco
Okay,
I have the motor mounts from the '88, and the ecu and harness from the '90.
I was told the waste gate and the blow off valve do the same thing and can basically interchanged, but I could be way wrong so any help would be appreciated.
Anybody have a ct26 wastegate for sale?
Ray.
Old 12-21-2007, 11:52 AM   #4
Chambers
Chambers's Avatar
A waste gate releases exes exhaust gases to stop the turbo from spooling up after a certain psi. You could buy headers for the turbo that have a flange built in for a divorced (external) waste gate, but you will have to keep the stock actuator on, just not connected to the pressure line, so the internal waste gate doesn't open. Or buy a manual boost controller that completely replaced the stock actuator, Greddy makes one, suprastore.com has them for like $190.
A blow off valve releases pressurized air out of the intercooler lines, when the throttlebody closes the air has no where to go, so a blow off valve is used to release that pressurized air so the turbo doesn't get compressor surge. compressor surge is when the pressurized air forces its way backwards through the turbo, this can destroy the turbo bearings. The factory "bov" on the Supra is actually a recirculation valve, it takes that pressurized air and feeds it back into the front of the turbo. The factory fuel maps correct for that increase in air, so you might need slight tuning if you put a bov on it, but I could be wrong. Hope this helped.
"Stuck in the 80's"
Old 12-21-2007, 10:04 PM   #5
Pretaco
Well that explains a lot.
Thanks for all your help.
Off to find a waste gate.......
2JZ 180sx driftcar (LOTS of questions) Nismo Drifting 11 01-22-2010 03:31 PM
Questions before buying a Supra proximityburn MKIV Supra 5 08-15-2008 02:09 AM
Some questions about my 1988 Supra... Somajunkie Non-Generation Specific Questions 11 06-18-2007 05:47 AM
