Old 12-20-2007, 09:44 AM   #1
west_side_supra
west_side_supra's Avatar
Default apexi safc? map ecu?
ok well i currently have the apexi safc in my car, wired up ready to go. well power house just sent me a free map ecu for making me wait on my new turbo manifold so now i'm wondering if i should just go ahead and put the map ecu in, from the looks of it, alot better way to run, i've heard of people running off of manifold pressure instead of maf sensor and getting much better results, plus the map sensor will get rid of that pesky maf sensor and give me less restriction.
now for the actual questions
who has ran this?
how do you like it?
there is a steel braided hose that came with the kit and i have no clue what it is do you?
any recommendations on were to put the map sensor? location on the manifold?
will this raise my fuel cut a little higher than 18psi?
and last but not least, this removes my MAF and will have no need for the safc anymore?
and if the case is that i go with this who will buy my safc and lexus maf?
7MGTE - 500hp never dyno'd
fidenza cam gears
Old 12-20-2007, 02:36 PM   #2
Chambers
Chambers's Avatar
From what I understand, If the safc has options and settings for MAP then you can use it, but I'm not familiar with it, you just need to adjust the wiring harness and the fuel/air maps. As for most of the other stuff, I couldn't help you with, sorry.
"Stuck in the 80's"
Old 12-20-2007, 04:33 PM   #3
Supra2NR
Supra2NR's Avatar
I could use that lexus maf
Sux you don't live close to me
Old 12-20-2007, 07:45 PM   #4
cyanide-is-a-way-out
cyanide-is-a-way-out is on a distinguished road
ill buy the safc since i already got the lexus maf and housing
cyanide-is-a-way-out is offline   Reply With Quote
Old 12-20-2007, 10:53 PM   #5
west_side_supra
well as for information on both items.
LEXUS MAF
90$ + shipping
housing and sensor
low mileage
Apexi safc
90$ + shipping
no damage that is see its in awesome condition and it works.
lots of extra wire.
fidenza cam gears
Old 12-20-2007, 11:28 PM   #6
west_side_supra
and my cooleze accordian hose replacement will be for sale also i want to say 125$ + shipping but i have to look at my receipt
fidenza cam gears
Old 12-21-2007, 04:57 AM   #7
Supra2NR
Supra2NR's Avatar
can you take a pic of the accordian hose?
Old 12-21-2007, 07:46 AM   #8
west_side_supra
here is the closest pic i have of it right now, same with the maf
fidenza cam gears
Old 12-21-2007, 07:48 AM   #9
west_side_supra
its a brand new hose, that is the closest its ever gotten to the motor itself, not 1 mile on it, still has the bolts in the holes.
fidenza cam gears
ANY ONE EVERY USE A Apexi Boost Controller donutking MKIII Supra 1 10-07-2005 01:58 PM
