Old 01-25-2008, 08:59 PM   #1
f00g00
The IAT is in your AFM, suprra_girl posted previously that it probably bit the dust. Did you try another?
The only adjustment ive heard of for the AFM is the tension adjustment for the flapper so it opens quicker.
Old 01-28-2008, 12:29 AM   #2
supramacist
supramacist's Avatar
Yes.
You go ahead and adjust your AFM.
I'll keep my 200 bucks.
Lexus 550cc injectors are the largest that I know of anyone using.
If you didn't replace the grommets for the injector to head application.
That 3$ piece of rubber you neglected is going to cost you some work sir.
Work smart. Not hard.
Good Luck.
Old 01-28-2008, 06:36 PM   #3
zambini
zambini is on a distinguished road
are you still running stock exhaust? i know the problem seems to be bigger than this, but if the exhaust smells funky, your 20 y/o cats are probably clogged and might be keeping your exhaust gasses from flowing properly.. not saying this is gonna fix everything, but might also be part of the problem.
peace
aaron
zambini is offline   Reply With Quote
Old 02-07-2008, 06:24 PM   #4
carfanatic89
carfanatic89's Avatar
carfanatic89 is on a distinguished road
well I pulled my dip stick and it smells like gas and I bought the motor from a shop that imports motors from japan it only has 50,000 on it now and when I replaced my camcover gasket I never took the injectors out, I know you need to replace orings. I want to do a fuel pressure test on the fuel rail and the tool you need (sst 09268-45012) is not availible to buy, is there anyway I can take out the injectors and test them out of the car. I think the problem it getting worse b/c now it smelll more like gas when trying to start.
Supra Engine Powered Dragster
carfanatic89 is offline   Reply With Quote
Old 02-07-2008, 07:47 PM   #5
carfanatic89
Just pulled the afm and all the resistances are within spec
Old 02-08-2008, 04:18 AM   #6
linuxgurupodboy
linuxgurupodboy's Avatar
linuxgurupodboy is on a distinguished road
Originally Posted by carfanatic89 View Post
well I pulled my dip stick and it smells like gas and I bought the motor from a shop that imports motors from japan it only has 50,000 on it now and when I replaced my cam cover gasket I never took the injectors out, I know you need to replace o rings. I want to do a fuel pressure test on the fuel rail and the tool you need (sst 09268-45012) is not available to buy, is there anyway I can take out the injectors and test them out of the car. I think the problem it getting worse b/c now it smell more like gas when trying to start.
your dipstick smells like gas? sounds like a head gasket or a cracked cylinder or majorly stuffed piston rings. One way to test it take off the oil cap and put hand over it. If you can feel pressure, that's not a good sign. Not too sure if it will work with the dipstick.
But I can't see why that will cause your engine to play up. Possible options are fuel pump or filter, Throttle position sensor, computer is fried, spark plugs and leads, timing maybe out, blocked air filter. But as Suprra Girl said, "do a diagnosis!!!!". But I'm pretty sure your piston rings are stuffed.
1990 3.0Ltr GT Turbo @8psi Manual (Converted)
linuxgurupodboy is offline   Reply With Quote
Old 02-08-2008, 06:48 AM   #7
carfanatic89
read the last line of my first post starting this thread
Old 02-09-2008, 04:39 AM   #8
supramacist
Get a bigger budget or a smaller car man.
87 Supra won't start RNEMESiS42 MKIII Supra 3 06-25-2011 06:30 PM
Car wont start hot carfanatic89 MKIII Supra 41 03-30-2009 10:58 PM
Supra wont start Micahwc MKIII Supra 1 03-14-2008 05:57 AM
Car Died...where to start? Jrew MKIII Supra 4 10-26-2007 02:19 PM
no start 87supraguy MKIII Supra 5 03-23-2006 07:31 AM
