Old 11-24-2007, 06:43 AM   #1
SCRAMJET
SCRAMJET's Avatar
Default core plug problem??
Hey guy's! my 1jz has a massive gushing coolant leak from somewhere above the oil filter. I'm guessing it might be a core plug. I dunno if there are any coolant pipes tucked in there, just can't see. Either way, i need to fix it. Is it possible to pull the inlet manifold off to without pulling the engine out of the car?
1jz scramjet mkiii
Old 11-30-2007, 06:09 AM   #2
suprra_girl
7M POWAH! ;)
suprra_girl's Avatar
i don't see why you can't just take the manifold off.
just pull the plugs from the ecu so you can take it off with the manifold
it's either frost plug or maybe the hoses going to the oil filter housing?
Pics of my build.
Do a diagnostic first!
Old 11-30-2007, 08:12 AM   #3
SCRAMJET
SCRAMJET's Avatar
Smile
All good! just a split hose! Need midget hands to get to it!
1jz scramjet mkiii
ABS Problem? rasclaat_98 MKIII Supra 6 12-13-2010 09:53 PM
another heater problem nicnet MKIII Supra 16 12-05-2007 10:18 PM
Plug or hose came off back of block f00g00 MKIII Supra 3 05-20-2006 11:01 PM
tsp problem for na t supra jdlee123 MKIV Supra 0 09-02-2005 06:01 PM
