Old 11-17-2007, 01:50 AM   #1
CyFi6
Rings could definately cause that, doesnt rule it out cause it doesnt smoke on startup, rings dont cause that kind of consumption. If you smoke on decell it could be valve seals, might not show on startup but could still be a possibilty.
Old 11-18-2007, 10:51 PM   #2
joebuffalo
joebuffalo is on a distinguished road
Compression test on all cylinders was between 160-170, that's why I was discounting the rings. Definately could be a crack in the head though. Anyone have any other thoughts?
joebuffalo is offline   Reply With Quote
Won't suck the water from overflow illusive38 MKIII Supra 7 05-24-2012 09:19 AM
Where the h--- is the water going??? illusive38 Non-Generation Specific Questions 1 05-27-2008 03:23 AM
Where the h--- is the water going??? illusive38 Non-Generation Specific Questions 0 05-26-2008 09:27 AM
Bad Water Pump? scruffboy Non-Generation Specific Questions 10 11-26-2006 04:37 PM
WAter not going back to raditor from recovery tank Help Jeff_5_7 MKIII Supra 12 09-15-2006 03:49 AM
