Old 07-13-2010, 09:07 PM   #11
SuperSpartan
SuperSpartan's Avatar
SuperSpartan is on a distinguished road
Originally Posted by plaaya69 View Post
The pipe on the charcoal canister should just vent into the air but it connects to a small hole in the frame. That is how it was on both of my 87 Turbos and also the peice that is broken is on the Powersteering pump is a valve that will go bad after some time.
Is your powersteering hard or does your ps pump make noise?
Really?? What would happen if the metal rod coming from the body was plugged to the bottom of the charcoal canister?? Cause it seems it was and it snapped, now im wondering what that hose coming out from the passenger body is??
1990 Toyota Supra Turbo!!
www.cardomain.com/ride/3067504
SuperSpartan is offline   Reply With Quote
Old 07-14-2010, 02:12 AM   #12
Wow, you've bumped a VERY old thread... don't know if any of the original posters will ever see it.
The fresh air inlet at the bottom of the charcoal canister is only held by a rubber grommet in the frame. The other end is not plumbed anywhere.... it just can't open into the engine bay in case fuel vapors should start venting out of it due to a bad valve.
Old 07-14-2010, 05:47 AM   #13
SuperSpartan
Turns out there was this metal rod connecting that hose to the hose coming out from the bottom of the charcoal canister, i knew it was there cause i saw the rod dangling and it had the other torn part of the hose with the clamp on it, yet i looked up hose diagrams and it shows that its supposed to be open to let air flow. So whats the hose (shown above) go to?
Edit: Sorry for the huge pic, but it doesnt expand further so guess its alright.
Old 07-15-2010, 01:03 AM   #14
Could be the drain for the condensation pan for the A/C.... I really can't remember.
Old 07-15-2010, 01:15 AM   #15
907mge
907mge's Avatar
I think that is for the a/c drain since it drips water on my aftermarket header.
Old 07-15-2010, 05:15 AM   #16
SuperSpartan
Thanks cre and 907!
I can now rest peacefully knowing thats not a issue, still concerned me to as why it was plugged to the bottom of the charcoal canister, time to talk with the last person to be in there haha. Thanks for the information again fellas
Vacuum line routing to HKS SSQV? mkiiisupra MKIII Supra 8 02-06-2008 05:29 AM
Vacuum line help 91toy supra MKIII Supra 7 08-25-2006 11:32 PM
Vacuum Line Deletion? Bullz_EyE MKIII Supra 1 12-24-2005 06:37 PM
vacuum advance/retard tonster MKII Supra 0 09-16-2005 06:43 PM
Fuel line problem Damian MKIII Supra 1 07-23-2005 10:22 PM
