Old 10-25-2007, 05:16 PM   #1
phill_54321
phill_54321 is on a distinguished road
Default Is it cheaper
ok, I Have an 86.5 n/a. i want to do a 1JZ swap and was wondering if it would be cheaper to buy an engine and transmission which is $1800 with like $450 shipping or a front clip which is around $2800.
phill_54321 is offline   Reply With Quote
Old 10-25-2007, 08:41 PM   #2
Supra2NR
Supra2NR's Avatar
jus buy the front clip, that way you know for sure, that you have everything that youre gonna need when doing the swap
Old 10-26-2007, 01:24 AM   #3
supradaddy0803
supradaddy0803's Avatar
I have already done my swap and I will recomend it to anyone to get a clip not just the motor and tranny. There is going to be a lot of things you will need from the clip that you wont get from just the motor and tranny. Like all of the plugs under the dash for example. They have to swaped no matter what most people think they dont have to but you can get plug and play adapters from driftmotion but it is easier and cheaper to swap the plug.
1987 supra NA 5 speed
1JZGTE swap
Tokico pillow blocks
HKS type 1 turbo timer
Walboro 255 fuel pump
JZA70 Front end mod
Old 10-26-2007, 03:50 PM   #4
phill_54321
thanks i appreciate the help.
86.5 N/A automatic
stock as Stock can get
looking to get a supra jslice13 MKIV Supra 13 09-03-2008 04:31 PM
2jz-gte cheaper than upgrades? GoddardJock Non-Generation Specific Questions 3 01-10-2007 09:37 PM
Where To Buy A Airflow Meter Cheaper Than $700??? anthony05 MKIII Supra 8 11-22-2005 04:30 AM
