Old 01-29-2006, 12:35 AM   #11
Dejvid1785
Dejvid1785 is on a distinguished road
Thanx for the help guys, i will find out tomorrow what the deal is. I have a whole day ahead of me. I will let yall know how it turned out.
88 Targa: Exhaust, Headers, Intake
Dejvid1785 is offline   Reply With Quote
Old 02-04-2006, 12:52 AM   #12
Dejvid1785
Its a blown head gasket!!! So i get to tear it all apart, my first time doing it, if anyone has any pointers or any kind of advice i would appreciate it.
Old 02-05-2006, 03:30 AM   #13
stumpjumper
stumpjumper is on a distinguished road
There are a lot of posts on this as this is a common problem. You MUST have the head milled and make sure the block surface is extra clean from past gasket material. Check for warpage and cracks on the block surface as well as the head. Overlooking this could cause another BHG. You will be replacing more than just the head gasket, i.e. the EGR gaskets. Buy a gasket kit. Keep track of the bolts, and take notice what connectors go where. Have patience. Good luck
stumpjumper is offline   Reply With Quote
Old 02-07-2006, 02:54 AM   #14
Dejvid1785
Thanx for the help! The only thing i need to know is where to order some ARP studs and bolts, it might be a stupid question, but its better to ask than to be sorry!
Old 04-06-2006, 09:35 PM   #15
supra41086
supra41086's Avatar
supra41086 is on a distinguished road
I have the same promblem whith my 88 supra.I cant figure it out???
supra41086 is offline   Reply With Quote
Old 04-07-2006, 01:59 PM   #16
toyosup
toyosup is on a distinguished road
Originally Posted by Dejvid1785
I don't have any smoke out of the exhaust or milky oil, but i am losing coolant!! Could that still be thermostat or something else? My temp gauge never stays still it sits up top showing that its over heating but the car isn't over heating and is driveable and suddenly it jumps back down, if anybody knows answer me. Thanx!
i just had same think...losing coolant,....the engine forcing coolant to the overwlow, and dump it out tru the drain house on the side of overflow...this is the gaket...maybe not broken, but definately bend around the rings on one ore more cilenders
toyosup is offline   Reply With Quote
Old 04-07-2006, 02:03 PM   #17
toyosup
make shure you mark the valve spacers were each one goes...they are diferent thiknes, and belongs to specific cilinder...i got my messtup once, and loose all the power
Old 04-09-2006, 04:36 PM   #18
gabit
gabit is on a distinguished road
I think the most common early head gasket problem is from the combustion chamber to a water passage. Think of it this way, the combustion pressures are far greater and hotter than either the oil/water pressures/temps while the engine is running...remove the radiator cap while the car is running, and see if there are any bubbles in the coolant... if "yes" ,increase the rpm, and see if they get worse...if you don't have water in the oil, you can probably seal it with any of the "solutions" they sell for fixing this type of gasket failure before the combustion gasses erode the gasket to an oil passage.
gabit is offline   Reply With Quote
Old 04-24-2006, 11:12 PM   #19
luggage
luggage is on a distinguished road
Looking for confirmation: I'm fixing a non-turbo and don't plan to do any major performance modifications (if any) to it. Is a non-metal head gasket sufficient (Felpro)? Are bolts sufficient? I'm assuming it had bolts from the factory and they will be fine if torqued properly. I mean new bolts, not the originals.
Now that I think about it: One of the reasons I want bolts is so I don't have to take the engine out. Wouldn't I just be able to insert studs into the top with the head in place to prevent having to remove the engine?
I see tons of posts about metal head gaskets but none about plain replacement gaskets.
luggage is offline   Reply With Quote
Old 05-03-2006, 10:49 PM   #20
rnoswal
rnoswal's Avatar
Plain gaskets work fine on an N/A engine. I put one on my daughters car along with ARP head studs and I think it will last a very long time. When you put the head back on after putting studs in, just leave the last 2 studs out like I did and you can tilt the head up from the front and get it to clear the firewall. Then just put the last two studs back in the torque it down.
You just want to make sur the studs go all the way into the block, which I noticed from my last car, that they didn't go all the way. They bottomed out but there were still a few threads left. You have to do it the one way because of the allen hole at one end of the studs. But it is working and my daughter ahs been driving it around for quite a while now.
Russ
HTML code is On
Blown head gasket? h8z2luze MKIII Supra 30 06-03-2006 03:18 AM
