Old 03-21-2008, 05:13 AM   #81
98fxdwg
98fxdwg is on a distinguished road
Default I understand
I see, I do want at least an 8" wide rim, and you're saying that +35 +40 is a good setup, I just want something that is right for sure before I spend the big money, there's no supras around i'm in redneckville idaho, so I don't have much to go off of. Also being in small rural redneck towns, the only wheel and tire dealers are small time and don't have much of an idea, they just work on lifted pickups, they haven't ever had to put a lowering kit on a car for instance, so I need your guys' help I will torque my own wheels b/c these idiots don't have a clue.
98fxdwg is offline   Reply With Quote
Old 03-22-2008, 04:39 AM   #82
Did a little bit of quick research, and it looks like that a common offset for 8" wide wheels is +30, which should keep that wheel tucked in pretty nice under the car without hardly any sticking out. 7" and 7.5" range between +35 and +40
Old 03-22-2008, 04:33 PM   #83
98fxdwg
Default Thanks
Thanks a lot man, they are on the way
Old 04-08-2008, 10:12 AM   #84
purnima1991
purnima1991 is on a distinguished road
Default get more info from Universal Technical
Even though most people think they must choose a hybrid vehicle to be truly eco friendly, consider some of the other options contained in this article. Depending on your driving style and budget, you might find you can make an equal contribution to the environment simply by choosing a more economical or more emissions-friendly vehicle.
get more info from Universal Technical Institute on programs of your choice
http://snipurl.com/-uti
purnima1991 is offline   Reply With Quote
Old 06-08-2008, 10:59 PM   #85
tojohny
tojohny's Avatar
tojohny is on a distinguished road
17x8 konig beyond on front w/ 245/40r17 kumho ecsta spt.
on the rear is 18x9.5 w/ 265/35r18.
both side walls are very close so it doesn't look funny but it is raked(font is 1" smaller overall diamiter)
Lord, I am walking your way,
let me in for my feet are tired, my cloth is ragged.
look into my eyes Lord, my sins will play out on them as if a screen.
forgive what you can and send me on my way.
I will walk on till you bid me rest.
tojohny is offline   Reply With Quote
Old 07-05-2008, 04:50 AM   #86
shiftysupra
shiftysupra's Avatar
Originally Posted by cars4me89 View Post
I will always recommend any kind of yokohama tires because i have never heard anybody have a negative remark about their tires. As for rims/wheels.. I like SSR wheels, they are expensive but they are some of the best on the market because most of their wheels are "lightweight" (under 20 pounds). Find them at Tire Rack - Your performance experts for tires and wheels also when they talk about rotating mass, they are absolutely correct. Your stock pulley on your 7M weighs 11 pounds.. the Unorthodox Racing pulley weighs about a pound. It will run about $200 from a store.. look for it on ebay. But reducing any weight on wheels or tires will make huge differences. Just remember that if you change your rim size that you might want to get your speedometer readjusted.. actually I'm not sure if you have to on Supras. Be sure to find out though.
Tell me how long your engine last before the vibrations from the balancer you pulled off. It's not worth the money. If you buy an underdrive pulley your taking off the dampener that keeps your engine from knocking or vibrating too much which will destroy your bearing. Only worth it if its a strictly race or drag car. Buy an underdrive that has a dampener on it... it's about 800 bucks though....
Old 01-26-2009, 07:48 AM   #87
87MK111Supra
87MK111Supra is on a distinguished road
I just got an MK3 and want to put some new wheels on it.
Will 19's fit comfortably without any rub or sticking out too much?
The tires would be 225/35/19.
Any help is really appreciated. Thanks!
87MK111Supra is offline   Reply With Quote
Old 01-26-2009, 03:02 PM   #88
Spudboy
Spudboy's Avatar
A lot depends on what you do or plan on doing with your car.
AND
Do you have stock suspension with stock ride height?
If you're still stock suspension and height those wheels and tires should fit. If you're lowered at all I would not do it.
I run 17" 235/45's all around with TEIN flex coilovers lowered as much as I can. No problem with the width but I do bottom out on my front fenders under hard bracking into a corner on a road course. I could actually go a little wider and maybe 18" in the back.
The big wheel with very low profile fad is just that...a fad. But not usually the best performance, and ride comfort sucks. Real performance tires have more sidewall to give the tire better strength under lateral g's.
But, if you just want to look cool and cruise around that 19" stuff should work. The width at least is fine and my guess with stock factory set-up height should be OK too.
Go to this link (or others) to punch in tire size numbers and compare.
Tire Size Calculator - tire & wheel plus sizing
Old 02-03-2009, 03:39 AM   #89
87MK111Supra
SO I ended up getting 225/45/16 Konig Traffik wheels all the way around.
Is there anyway to change the speedometer so it reads correctly?
Old 02-03-2009, 12:51 PM   #90
Spudboy
Spudboy's Avatar
I believe those tires are the about the stock size so your speedo should still be good.
FYI - In the future if you ever go bigger...some of those web sites for tire size calculators can tell you speedometer differences to expect. Unless you jack your car up and make it a 4 x 4 with huge tires the speedometer wont change much. (Keep in mind when people go bigger wheels they also go lower profile rubber so actual tire rubber outside diameter doesn't change that dramatically)
HTML code is On
water build up in spare tire wheel, 87 supra---any solutions?????? ogkush MKIII Supra 5 09-17-2011 09:42 PM
wheel fitment - who wants enkei? carl johansson MKIII Supra 7 03-25-2010 12:56 AM
replacing wheel stud Rahnter MKIV Supra 3 12-10-2008 03:57 PM
edgeracing.com - wheel & tire packages Nato99 Non-Generation Specific Questions 5 06-22-2007 04:33 AM
