Old 06-17-2008, 07:14 PM   #61
edmonton
edmonton's Avatar
edmonton is on a distinguished road
Originally Posted by thomatt12 View Post
The first thing you should modify IMHO is your I-H-E, meaning try changing the Intake, Headers, and Exhausts. It will give you some extra power I believe. Good luck!
Originally Posted by TheEngineer View Post
When i first bought my supra (it's an 88) it had a very small exhast leak that i decided to get fixed. Even though it was a small leak it was a enough to make my car sound like crap. For about $130 i got a custom exhast that not only looked and sounded way better, it sure felt like i was getting more horse power too. Im not sure if i had any thing blocking or resisting my exhast but i think the $130 was well worth it.
I agree, the 7mgte responds very well to exhaust mods. The stock piping is too restrictive. I bought my supra with a 3" muffler and it looks like 2 3/4" piping already on it and i've whooped other stock turbo supras. It could be their driving but I've blown them out so it looks like any driver could of done the same. plus it sounds good!
i'll be doing the CAI next if i can find a good write up so I can just but the right angled tubes from the store, then possibly headers.
edmonton is offline   Reply With Quote
Old 06-28-2008, 07:04 AM   #62
toneloc87 2
toneloc87 2's Avatar
toneloc87 2 is on a distinguished road
Originally Posted by 88Tsupra View Post
I've heard of the CF drive shaft being stronger then the aluminum ones.
I didn't read through this thread. But a BIC DDP 3inch is worth the money. My car feels way better with the DDP mainly right before boost and keeps the power going all the way through
i hear the carbon fiber ds is stronger but is for track use only because if a rock flys up and hits it will shatter
toneloc87 2 is offline   Reply With Quote
Old 07-22-2008, 05:32 PM   #63
Moses76
Moses76 is on a distinguished road
I have a 87 NA also that I'm trying to make a little faster. What's an EGR valve? And an AFM? ThankX!!!
Originally Posted by supra_91 View Post
you don't have to replace the headgasket unless your going to go for major horsepower or if your car has a lot of miles on it
i have a N/A and i have a K&N cold air kit, 2 1/2" catback exhaust. i also blocked off the EGR valve and i loosened the tension of the spring in the AFM.
this next month i'm getting a header, dual electric fan, cam gears, timing belt, and a chip
this will be pretty much close to max power without tearing into the engine
Moses76 is offline   Reply With Quote
Old 12-04-2008, 03:02 AM   #64
DSM
DSM is on a distinguished road
I was told that if you use a MAF out of a 92-96 Lexus GS400 it gains a good amount of HP paired with a boost controller. I was told that 16-17 PSI was capable safely...? Anyone tried this?
DSM is offline   Reply With Quote
Old 12-21-2008, 11:48 PM   #65
Mahonri
Mahonri is on a distinguished road
About 15 Psi is you go higher then you will deal with Fuel Cut...
Mahonri is offline   Reply With Quote
Old 03-17-2009, 01:47 AM   #66
suprastar87
suprastar87 is on a distinguished road
Default 7mgte
anyone know where i could possibly buy a new fan shroud for an 87 turbo supra?
suprastar87 is offline   Reply With Quote
Old 03-22-2009, 07:16 AM   #67
Suprafreak
Suprafreak's Avatar
Suprafreak is on a distinguished road
hey do you know any reliable resources on where i can order parts?
proud owner of a fresh 87' supra
Suprafreak is offline   Reply With Quote
Old 04-06-2009, 03:47 AM   #68
Starlight1988
Starlight1988's Avatar
Starlight1988 is on a distinguished road
Hey, does anyone know what, where, or how to get custom carbonfiber parts for the supra mk3. like roof, doors, and stuff like that
zoom zoom!
Starlight1988 is offline   Reply With Quote
Old 05-12-2009, 02:15 PM   #69
mk3teen
mk3teen's Avatar
mk3teen is on a distinguished road
im pretty much in the same situation. Anyone know of a quite exhaust that can still roar when i floor it in my 89 turbo. Another question if i add a cold air intake, would i have to retune the car??? Also what is the max power i can put inot the car without haveing to replace the gasket or forge the pistons?
mk3teen is offline   Reply With Quote
Old 05-12-2009, 03:47 PM   #70
kwnate
http://store.driftmotion.com/static/...ormk3supra.php
I have this on my 1j, can't tell its on at idle or cruise. Step on it hard and it sounds mean. It doesn't look like the picture either, its an oval canister.
Nate
HTML code is On
Best Bang For Your Buck 1988 Supra turbo jordanlovesmk3 MKIII Supra 3 07-26-2009 04:37 PM
