Old 08-29-2009, 05:45 AM   #11
srzsmack
srzsmack is on a distinguished road
what i do is get a rolling jack anduse the jack to lift it as you aim it into place.
srzsmack is offline   Reply With Quote
Old 01-06-2010, 04:08 PM   #12
11Ton Butterfly
11Ton Butterfly's Avatar
11Ton Butterfly is on a distinguished road
I'd like to thank you guys for the info I'm having the same problem and found this on a google search.
11Ton Butterfly is offline   Reply With Quote
Old 04-06-2010, 05:17 PM   #13
Diovox
Diovox is on a distinguished road
I have an 88 Toyota Supra Turbo. I am trying to replace the transmission and I am having trouble getting at the nut above the starter(hopefully the last one). I can see the bolt but i have little to now room to move a wrench and a ratchet wont work either. Is there something else I need to remove before trying to take this nut off?
Diovox is offline   Reply With Quote
Old 04-06-2010, 10:41 PM   #14
Busted Knuckles
Busted Knuckles's Avatar
I've had to do this 3 times in a row over 2 days, then another time removing the transmission. My trick was to use a 14mm (or was it 17mm) box end on the nut just above the starter, and use a ratchet with a loooooooong extension to get to the bolt head on the transmission side from underneath. Still a PITA, but it worked.
HTML code is On
86.5 auto transmission removal HELP!!! elmer MKIII Supra 13 04-06-2010 10:41 PM
auto transmission issue 87-POSupra MKIII Supra 2 03-26-2009 05:12 AM
Auto Transmission Swap big_kahuna89 MKIII Supra 1 06-13-2008 11:13 AM
Need transmission removal help ASAP FunWheelDrive MKIII Supra 2 03-23-2008 12:35 AM
