Go Back   Toyota Supra Forums! Join the Supra forum! > Performance, Modification, and Maintenance Forums - for generation specific discussions > MKIII Supra > MKIII FAQ
Old 07-18-2010, 05:48 PM   #3
A fastener supply in just about any city should carry these bolts and grommets. The bolts are easier to work with but do not use them as an excuse to over tighten the covers. The spec is 22 INCH pounds for a reason.
I'm still waiting for someone to go with spring loaded fasteners with 2lbs springs.
HTML code is On
Valve cover vent hose Durandal MKIV Supra 3 07-14-2009 01:53 AM
Need a 14mm allen head bolt for valve cover trevor217 MKIII Supra 4 10-30-2008 02:50 PM
valve cover gasket question? sevenmgte MKIII Supra 8 10-01-2008 06:02 AM
88 Turbo Leaking Valve Cover Gaskets Sheridan MKIII Supra 1 11-05-2007 01:03 AM
Valve cover gaskets vancouver874 Non-Generation Specific Questions 7 08-14-2006 07:28 PM
