Go Back   Toyota Supra Forums! Join the Supra forum! > Performance, Modification, and Maintenance Forums - for generation specific discussions > MKIII Supra > MKIII FAQ
Old 05-13-2010, 11:43 PM   #1
joshtexican
joshtexican is on a distinguished road
Default APR Head Studs and Head Torque Information
Hey I have a quick question:
Does anyone know the order in which the head studs are supposed to be torqued? Or a basic procedure as I am getting ready to assemble my motor back together and I am about to torque the head to block.
Thanks in advance
joshtexican is offline   Reply With Quote
Old 05-13-2010, 11:59 PM   #2
907mge
907mge's Avatar
Here is what you need. Use it well.
http://www.cygnusx1.net/Supra/Library/TSRM/MK3/
Old 05-14-2010, 03:16 AM   #3
joshtexican
Hey call me slow but I didn't see what I needed in there!! haha sorry man..
Does someone think they can explain a little to me an order in which these head studs are to be bolted or torqued down?
What I'm looking for is maybe like an order, for example:
2 front studs then,
2 back ones then,
middle studs...or something along those lines-or maybe it does not matter, idk.
And of course at the end they will all be tightened somewhat equally, then get torqued.
I'm new to the whole process and trying to learn as I go, If someone could help me out a little or explain that link that was posted I will greatly appreciate it.
Old 05-14-2010, 03:57 AM   #4
It's the opposite of the removal order. I hope you didn't just pull them out in any old order...
Here's the specific chapter for the head: http://www.cygnusx1.net/Supra/Librar...ection=EM&P=32
Old 05-14-2010, 08:07 AM   #5
Bill UK
AEM EMS
Bill UK's Avatar
Tightening Sequence
Old 05-14-2010, 10:21 AM   #6
907mge
907mge's Avatar
Sorry just figured i'd give the whole link since there is more to puting the head on than the head studs like the cam cap bolt sequence.
Old 05-14-2010, 01:14 PM   #7
joshtexican
907mge- I am still going to use that link bro, I just wanted to see the tightening sequence as Bill UK shows. But thanks to all!
I am going to torque her down this evening!!
Old 06-05-2010, 01:12 AM   #8
joshtexican
So I am trying to torque the heads down on the 7mgte and the ARP head studs still have a little thread over the block.
Is this a major issue?? I knew nothing about this and didnt catch it until now.
Can someone tell me if I can procede with the torqueing?!?
thanks
Old 06-05-2010, 01:17 AM   #9
wstanek
wstanek's Avatar
wstanek is on a distinguished road
now from my knowledge you can but ask some other ppl i dont wanna fck ur car up ;D
wstanek is offline   Reply With Quote
Old 06-05-2010, 01:59 AM   #10
If you've made sure the holes are clean (no debris inside) and you've chased the threads then you have nothing to worry about. That's the nice thing about studs, unlike head bolts you don't have to worry about the one side where the torque will be read hanging up and causing a false high reading.
HTML code is On
Bolts? Studs? Blackdog MKIII Supra 9 01-12-2010 06:42 AM
Arp Head Stud Torque Settings!?!?!?!?!? papaleach MKIII Supra 2 11-22-2006 08:20 PM
Head Bolts, Or Head Studs?? ZauggIt1 MKIII Supra 2 08-08-2006 01:23 PM
Torque Specifications (ARP Head Studs)??? Dejvid1785 MKIII Supra 5 03-06-2006 02:59 AM
