does anyone know any good sights to buy a good exhaust system from...preferably one with like no welding required...and maybe a header...any info would be great...
or should i just go to my local muffler shop and get it from them... |
Here ya go..
http://www.rabidchimp.com/mk2sup_cbexhaust.htm Or do like me and have someone put you in a 2.5" piping all the way back from collector to muffler..No cat..No resonator..
83 p-type,5spd,4;10 gears,New 86 cressida 5MGE 195hp,HKS metal head gasket,Cressida injectors,d-port intake runners,No EGR,No cat,Tweaked MAF,Custom cold air intake,Custom rear strut bar,Perfection clutch,Custom 3inch exhaust,4inch bazooka muffler,,Only 2700lbs,, COME AND GET IT!IF YOU DARE!! Please no Honduuuuhhhs!!! http://www.cardomain.com/ride/858848/2 |
see i would do that except in washington you have to pass an emissions test...and it couldnt without a catylitic converter...otherwise i would
you build a section of 3 " pipe to bolt on where the cat goes when you are not getting emissions tested.
#5 | |
ok...so ruling out a pipe from collector to muffler, can anyone recomend a DECENT(not looking for performance or racing, just need one other than the one that came on it in 1984) cat back system in the 200 dollar range
what about the pacesetter monza system?
#6 |
i'm sure you can get all those item from your local auto part fo under $350 and its a peac header header and a bosal or something like that and it come with a direct fit.... no need to modification i mean no welding... it bolt right up....
and also performance and it also past smog inspection too.... its a stock item... |
#7 |
go to www.935motorsports.com. they have quite a few options and offer a pacesetter system for under $200.
82 Ptype (6mgte project) |
| Exhaust for 7MGE | XtreeX | MKIII Supra | 19 | 03-25-2010 01:39 AM |
| Exhaust Cat Fitting | Bill UK | MKIII Supra | 4 | 06-15-2008 11:32 AM |
| exhaust question (not in exhaust faq) | sd88supra | MKIII Supra | 21 | 11-28-2006 10:52 PM |
| Dual exhaust, anyone? | lifesnotfair | MKIII Supra | 13 | 12-22-2005 10:41 PM |
