Old 02-19-2006, 01:08 AM   #1
cooley346
cooley346 is on a distinguished road
Default gaskets
My 82 was leaking oil so i'm putting on new gaskets. it was mostly coming from the cam housing. Since I'm in there I figure I'll just go ahead and replace the rest of the seals and gaskets on the front of the motor, Including the cam seals. Everything on front. I've already got the cam tower gaskets. Do I need both the head gasket set and the conversion set.
cooley346 is offline   Reply With Quote
Old 02-19-2006, 04:07 AM   #2
midwestmk2
midwestmk2's Avatar
midwestmk2 is on a distinguished road
If you want a head gasket that will not leak at all get the HKS metal gasket and the conversion gasket set..The rear cam seals hardly never leak and should be fine..The oilpan gasket can be replaced with just silicone gasket sealer..That should cover your bases..
83 p-type,5spd,4;10 gears,New 86 cressida 5MGE 195hp,HKS metal head gasket,Cressida injectors,d-port intake runners,No EGR,No cat,Tweaked MAF,Custom cold air intake,Custom rear strut bar,Perfection clutch,Custom 3inch exhaust,4inch bazooka muffler,,Only 2700lbs,, COME AND GET IT!IF YOU DARE!! Please no Honduuuuhhhs!!!
http://www.cardomain.com/ride/858848/2
midwestmk2 is offline   Reply With Quote
Old 02-28-2006, 06:19 AM   #3
hangsupra
well... if you think you want a perfect motor with no leaking then why dont you tear apart and replace all gasket and all the cell..... that will solve the problem....
valve cover gaskets are leaking D_Train MKIII Supra 18 03-19-2015 04:53 PM
Supra head gaskets? MA61ME MKII Supra 12 01-17-2012 01:48 PM
types of gaskets? brandonsupra MKIII Supra 7 01-23-2007 03:31 PM
Valve cover gaskets vancouver874 Non-Generation Specific Questions 7 08-14-2006 07:28 PM
