Old 02-15-2006, 04:40 AM   #1
suprajohnny
suprajohnny is on a distinguished road
Unhappy Help, New Pump Still No Power Steering
I just replaced the PS Pump and pressure line in my 1990 turbo. But still unable to turn wheel w/out really putting some muscle behind it.
I assume the new pump is good since I got it from Toyota, but is there any way to check it.
Whats else should I check?
What about this "progressive power steering" is it computer operated, is it possible that the computer or a relay or something has died?
Is there some way to check the rack instead of just replacing it?
Thanks a million-SupraJohnny
suprajohnny is offline   Reply With Quote
Old 02-22-2006, 04:54 PM   #2
Isphius
Isphius's Avatar
the pump in the rack is probably bad. i dont know if its a pump...but the thing the pressure line goes to. you might have to replace the rack too. where did you get the power steering line from? i need one of those...
Old 02-28-2006, 06:14 AM   #3
hangsupra
is the '90 supra n the 82-85mk2 using the same pump.... i toght its difference isn't?
Power Steering Pump Whining Chambers MKIII Supra 10 01-28-2010 07:19 PM
power steering pump daluxsrt4 MKIII Supra 1 08-29-2008 02:17 PM
Power Steering Pump and Fluid Chambers MKIII Supra 8 06-29-2008 03:59 PM
Power steering pump carfanatic89 MKIII Supra 1 09-15-2007 04:16 AM
Power steering pump.. 89 turbo. 2JZEFINI-17 MKIII Supra 4 03-13-2007 03:23 AM
