Old 02-22-2013, 01:17 AM   #1
mowvideo
mowvideo is on a distinguished road
Default Location of horn relay
Hi
I have a 1985 P type Supra and the horn has quit. The horns and relay are fine as the theft deturant system sounds them ok
I have taken the wheel off and the contact is fine to the ring on the wheel. Ohmmeter shows continuity when the button is pushed. Somehow a wire has broken between the relay coil and the steering wheel. I can't find an 85 manual. Does anyone know where the horn relay is mounted on the 85?
Thanks Mike
mowvideo is offline   Reply With Quote
Old 02-24-2013, 06:29 PM   #2
http://www.cygnusx1.net/Supra/Librar...Section=BE&P=7
im not sure if there is such a thing... did you check the fuse box by the drivers feet or in the engine bay??
Old 02-24-2013, 11:36 PM   #3
The functionality of the theft deterrant system's horn doesn't mean anything. I have yet to see a Toyota, factory alarm which didn't have a seperate horn for the alarm system. Looking at the wiring diagrams neither the alarm horn nor the two hazard horns have a relay.
Wiring diagram for the two hazard horns:
http://www.cygnusx1.net/Supra/Librar....aspx?S=E&P=13
Dome Lights btwilson86 MKIII Supra 6 04-03-2011 01:05 PM
Dome Lights btwilson86 MKIII FAQ 3 04-03-2011 01:05 PM
Where is the fan relay on an na supra? batmmannn MKIII Supra 2 06-19-2010 01:40 AM
Starter Relay? Passenger Kick panel? dannydavi MKIII Supra 8 09-24-2007 01:12 AM
