Old 09-26-2011, 04:06 AM   #11
ID:	4224Click image for larger version
gona throw some green in there because i can...
Old 10-01-2011, 06:32 PM   #12
all clean and painted up
Old 10-04-2011, 03:51 AM   #13
87hilux7mge
87hilux7mge's Avatar
its all lookin slick bakin'. keep it up man! i got a line on a 2uz up here, might try to pick that up for a later swap
Old 10-07-2011, 11:54 PM   #14
got my adapter plate the other day.
also i have decided to go with a carb.
Old 11-18-2011, 01:44 PM   #15
going with a custom intake manifold carb. and coil packs with ford edis8 ignition.
also ordered up some new w58 shifter bushings from billym on celicasupra.com 49$CAD comes to my door
Old 11-18-2011, 05:15 PM   #16
87hilux7mge
boo on the carb. efi would be so much nicer. get MS2 or 3, only a lil more than the carb and manifold will run prolly, and youll get more power, better drivability, plus you dont have to run EDIS if you dont want. can run some individual coil packs from a caddy, dodge, mitsu, etc... thats what im doin.
ms2, relay board, wiring harness and all the data cables runs about 560 bux.
Old 11-19-2011, 02:45 PM   #17
na, i think im going to buy another mk2 supra and start a 7mgte build possibly...
i want my 1uz to be carb, its not about achieving more power in the end or being more efficient, carb, and edis8 with coil packs, and my engine will only need 3 wires to run, plus the engine looks so sexual with just a block and heads...
check out the pictures of 1uz's:
http://www.gt40s.com/forum/rcr-forum...e-ideas-4.html
Old 11-27-2011, 05:23 AM   #18
87hilux7mge
true i guess. a simple setup is nice, but id still keep the EFI. poor fuel distribution through a carb and improper manifold can grenade an engine quick..
but hey it will probably work, gonna be a high rpm motor for sure! thinking a 500 edelbrock or 550 demon carb would be pretty sexy and perform the crap out of that thing.
Old 12-11-2011, 03:21 PM   #19
found some engine mounts finally. i havnt much time during the week to fab up 1uz to ma61 mounts so this is really going to help:
http://www.xcessivemanufacturing.com...step=4&pid=269
http://www.ksracing.net/forums/index.php?topic=7546.0
these guys sell flywheels and bell housing that uses the w58's fork and slave cylinder.
gona have to go flywheel from these guys because i have still got got mine from quantum auto
but on the up side i can get edis8 kits ready to go for cheap
http://www.ebay.ca/itm/EDIS-8-Igniti...item1c21a8e9fd
Old 12-11-2011, 08:06 PM   #20
87hilux7mge
nice! ive got an edis8 module but no crank trigger wheel. im not gonna use it though. they are a pretty good system, and simple as all get out.
stoked to see that thing in the sup and running. scurrin ppl!
