Old 06-22-2011, 09:32 PM   #1
DaddyOH!
DaddyOH! is on a distinguished road
Default MKII OEM Security System Removal
Do not know if it is the same, but on my 85 I was having trouble too. Felt silly goin down the road with the lights flashing! Found a little box below the rear passenger side armrest tucked way down in there that said "security warning" on it. Unplugged it and viola! no more flashing lights and no side effects so far!
DaddyOH! is offline   Reply With Quote
Old 06-23-2011, 01:22 AM   #2
Props for posting in a 6 year old thread. I'm sure this has since been covered.... and the MKIII system is more sophisticated.
I didn't know there even was a factory alarm on the MKII... Toyota's smarter than that and wouldn't put it in the open... possibly a dealer add-on (and poorly installed if the car worked fine with it just pulled out).
Old 06-23-2011, 04:21 PM   #3
DaddyOH!
Signed up to the forum mostly JUST to post to this old thread because I could not find the answer out there and had to figure it out on my own. Just trying to help out. The small box I referred to is not in the open. You have to remove the driver's side rear passenger armrest and really get down low between the inner and outer sheet metal to access it. It is stamped with TOYOTA, and has a part number below that.
Old 06-23-2011, 07:13 PM   #4
Relax, if it really was a bad thing I would've just deleted it. But, this does belong in the MKII section, not MKIII; they're obviously wired differently, bypassed differently and they're in different locations (The MKIII's is above the steering column and a tny bit of rewire is needed).
I'm moving this to its own thread in the MKII section.
EDIT:
I looked up a wiring diagram. WOW, that really is a somewhat pointless system... Rip the box out or cut the wires and that's it... not even a starter cut-out...
Here's an online link for an '86.
http://www.cygnusx1.net/Supra/Librar...ection=BE&P=87
trouble with security system derekrd Non-Generation Specific Questions 4 06-05-2013 07:05 PM
Intercooler system choices? Need help to choose. Bl@ckh3art MKIV Supra 5 05-22-2011 01:59 AM
security system 87 turbo supra ???? supranutz Non-Generation Specific Questions 1 11-15-2009 12:33 AM
One more time, my air removal method. Monkey Non-Generation Specific Questions 2 04-20-2007 02:09 AM
Car security system bigal0043 MKIII Supra 1 09-16-2005 09:50 PM
