Old 04-04-2011, 02:11 AM   #1
Default 5m build
http://www.toyota-supra.info/forums/...albums197.html
5m Turbo
Parts needed*
*IC and more piping
*Low compression pistons
*7m Metal HG
*better connecting rods.
*Bearings all around.
*rings
*clutch that can handle a turbo
*Lash adjusters for head.
*injectors and clips
i have yellow top 7m n/a's but i need clips.
*fuel pump
*FMU
*ct26 heat shield
*adjustable cam gears
*oil Pump
list is gona grow, i got alot going on this summer so its gona be slow...
any advice would be awesome. this is my first 5m build up!!!
Old 04-07-2011, 01:25 PM   #2
have a complete 5m block.
after hitting it with a strait edge its been stripped down.
while removing the crankshaft i noticed bearings for connecting rods in cylinders 2,5,and 6 were warped.
cylinder walls are looking rough, im thinking im gona get them bored.
Old 04-22-2011, 09:56 PM   #3
5m block is in for machine work, possible bore, but i am still looking for pistons
crankshaft is getting reground, and fitted for new bearings.
and i am staying with stock rods.
Old 05-03-2011, 08:02 AM   #4
87hilux7mge
87hilux7mge's Avatar
i have a few sets of injectors that might work for you.
set of ls1 36#hr injectors w/clips, low Z (off 98 buick regal supercharged motor)
set of injectors from buick pk ave ultra (supercharged) 24#hr with clips
can prolly work up some toyota injector clips too.
i have a set of 5m connecting rods too, id just shot peen them and have them reconditioned, then balance everything. (balancing rod/pistons isnt that hard, and most piston kits are already balanced +/- .5 grams, the crank is the only piece that the machine shop would do, or just have them do it all for like 250-275)
u can use the turbo type piston kits from the 7mge as they are the same bore increments, that would take care of the pistons and rings.
bearings id go with clevite 77's or king/acl.
u can pick up an hks mhg on ebay for 100 delivered, 1.2mm thickness
an f1 racing clutch wouldnt be bad, stage 2 is a carbon disk hd unit, thats what im using and they get decent reviews, mine was 150 shipped.
i have a couple 7m oil pumps, ones a supra style mid sump, the other is a front sump style. ive cleaned them, but havent checked lash. they both were in running motors.
Old 05-03-2011, 09:51 PM   #5
this is gona have to be set back a year or so i just picked up a lexus LS400 with a 1UZ that i plan on swapping.
so my 5mgte build will be on the bench for a while...
but thanks for reply
Old 05-03-2011, 09:56 PM   #6
87hilux7mge
hell yea man, thats sick that you found a 1uz, i cant find one here for beans. last one i found the guy wanted like 1500 for the motor with over 180k on it.
itll be sick in the car tho, super light and way powerful.
ill prolly have lots of these parts for a while neway, im a pack rat lol. lemme know if you wanna toss a supercharger on top of that 1uz i got a couple layin around haha.
good luck with it man!
Old 05-05-2011, 11:31 PM   #7
i would love to supercharge, but i have to lift my 4x4 this year, i promissed myself that i would, haha
Old 05-06-2011, 03:44 AM   #8
87hilux7mge
sweet deal, thats on my list too. what you got for a 4x4?
trying to decide whether or not to keep my IFS or do a SAS for my truck. itll cost me about the same in the end.
ifs rides so nice but the sas is robust and flexes better (not that i care cuz im not extreme).
Old 05-08-2011, 09:56 PM   #9
got a 87 suzuki samurai. probly gona make some custom springs, until i can afford some old man emu's probly go for a 3-5 inch lift. and some larger tires and some wheel spacers...
http://www.toyota-supra.info/forums/...28-my-4x4.html
Old 05-09-2011, 02:18 AM   #10
87hilux7mge
nice, i always thought a good zuke would be fun. couple of my buddies have them. ones on a toyota frame n running gear rocking a small block. the others on 4.88 toyota solid axles with the stock motor/tranny.
urs should be pretty sick! i only wana be able to run 33's at most. found some sick fiberglass body parts for mine the other day, 3 inch flares for beds and fenders, looked pretty sick!
neway, good luck with it all, keep updating when you make some progress.
7mge build with some questions. 87hilux7mge MKIII Supra 34 06-11-2014 09:04 AM
My First Build Cameroonski MKIII Supra 7 01-04-2011 11:42 AM
