Old 12-14-2010, 01:16 AM   #1
MarkII84
MarkII84 is on a distinguished road
Default backfire/rough idle
So my mark 2 is back firing and isles rough. My idle is at 450 cold and 800 warm is this normal??? HELP!!!
MarkII84 is offline   Reply With Quote
Old 12-18-2010, 05:22 PM   #2
back firing could be a hole in your exhaust system.
if you doubt your timing is correct...
http://www.cygnusx1.net/Supra/Librar....aspx?S=IG&P=1
its not hard to check if your belt is worn either:
http://www.cygnusx1.net/Supra/Librar...Section=EM&P=7
Old 12-18-2010, 07:10 PM   #3
MarkII84
My timing is perfect I already checked...but I am positive I have an exhaust hole. I was just curious if that was it cuz I messed with my idle and was wondering if I had to much fuel or it was a objectors problem
Old 12-19-2010, 01:51 PM   #4
as long as you did it "by the book" your timing should be fine.
checking your injectors is never a bad thing. they have filters,
Old 12-19-2010, 04:56 PM   #5
MarkII84
Define by the book.....and where aroe the filters??
Old 12-19-2010, 10:18 PM   #6
http://www.cygnusx1.net/Supra/Librar...2/default.aspx
idle problems 88 supra turbo MKIII Supra 14 03-13-2010 03:43 AM
Car wont idle (wont stay on) Kevin MKIII Supra 29 09-02-2009 02:07 PM
1987 Toyota Supra Idle spycialost9999 Non-Generation Specific Questions 3 06-14-2006 06:33 PM
