Old 11-16-2010, 07:08 PM   #1
90Fletcher
90Fletcher is on a distinguished road
Default New Guy...Engine Needs Time Please Help
Hey New to The Supras. Not Heavily Into Imports but I Want to Expand My Knowledge and Not Have A Close Mind.
Im Planning On Getting An 82 Stock. but it needs to be timed.
My ? Is Has Any1 Time Their Engine be4 Themselves? If So Was It Easy or A little More Effort Than Forcasted? And Some Steps Would Help Me 2.
Or Maybe A Link To Answer My Question, like a "how to".
...If You Got This Done By A Shop How Much Did It Cost?
Thanks 4 Any Feedback.
90Fletcher is offline   Reply With Quote
Old 11-16-2010, 08:46 PM   #2
http://www.cygnusx1.net/Supra/Librar....aspx?S=IG&P=1
If you're only referring to the spark advance (aka ignition timing) you may skip to page IG-10. I believe this will be the same on your car as it was for the 86 which is the year this manual was written for.
Old 11-16-2010, 11:24 PM   #3
90Fletcher
Ok Thanks- Yes The "ignition timing" is What Im Referring 2.
If I Do Get The Car I'll Let You Know How It Went
thanks again
Old 11-20-2010, 04:40 PM   #4
there is little difrance between 82-86, im using an older head on my 84 right now.
make sure to use a timing light and jump T and E1
Ignition Timing is 10 degree's @ BTDC @ T and E1
good luck
Old 11-20-2010, 06:13 PM   #5
I was thinking of electrical changes. Toyota changed the ECU construction in the middle there and the diagnostic connectors changed along with a fair amount of wiring... I just don't know all the details.
I just looked it up and Toyota switched the MKII to their TCCS system in '83. So it's probably '82 and some '83 (L-Type vs P-Type). If anyone has more info or info to the contrary I'd like to know, I'm just going off of a quick survey of Google and CelicaSupra.
Old 11-21-2010, 12:54 AM   #6
http://www.celicasupra.com/forums/sh...ences-in-years
worth reading if you like the mkII
its mostly about appearance and hp ratins and rear end/trans. ratios.
Old 11-21-2010, 01:17 AM   #7
82, has the 145hp and 150ft/lbs of torque 8.8:1 compression 7.72 gearing. vacuum advanced dist.
86 has 161hp and 169ft/lbs of torque differant style tps and egr knock sensor
5speeds:4.30 gears auto:4.10 gears electronic dist.
i am still looking for more on wiring differences...
Old 12-18-2010, 05:13 PM   #8
http://www.celicasupra.com/forums/sh...043#post699043
some good info on what year ecu and harness's are compatible
Putting JDM engine in!!! :D dannydavi MKIII Supra 24 11-02-2009 06:30 AM
