Old 10-16-2010, 02:57 AM   #1
Default 5m cranks but will not start
so i had a cracked head, i replaced it with an older 5mge head and obviously did my HG. i replaced out the old distributor with the one from the head i removed(dist. had some sort of vacuum advance.) also replaced the thermostat housing thing, with the one off my old head.
also put in injectors and fuel rail i just had sitting around.
the engine cranks, but isnt starting.... any thoughts??
im gona check to make sure im getting spark later on this weekend...
i set the #1 cylinder to TDC and both cam gears to proper marks. dist. may be a bit off but it should still start.
and before i did the job, i was getting spark....
i really hope there was just some bad gas in the injectors and rain i put on and its gona take some cranking to get it out
any thoughts would be good
Old 10-19-2010, 05:02 PM   #2
Travis89Turbo
Travis89Turbo's Avatar
My guess would be that the dist. Is 180 out. Pull the dist. Crank the motor over one full rotation till the marks are lined up again and re install the dist. Give it a shot let us kno
stock 2jzge
1999 Ford F350 diesel
2004 Jaguar XJR Supercharged
Old 10-20-2010, 03:23 AM   #3
lol actually, it turns out my old head, the cam marks were "t" marks, on the head i just put on there has both a t mark AND an "E" mark.
but for some reason the old heads marks were the t marks
i asked at celica supra.com and was told the proper marks were the e marks.
so i had the cams 180 out.
but it still does not tell me why my old cam gears proper marks were the t
and i know they were becaue i set it to tdc before i pulled the head off.
also my timing belt doesnt want to go back on, so i think its done for gona put a new one on this weekend..
Old 10-22-2010, 07:57 AM   #4
bioskyline
ive ran into this issue to. the 82-83 5m using different timming marks than the 84+. the belt and gears are also different, the 82-83 use a rounded tooth design where the latter used a flat tooth design.
why they changed is a mystery, maybe to make it easier to time the engine?
Old 10-22-2010, 11:57 PM   #5
yea its kind of an off thing to have timing marks then another set of marks exactly 180 to the really marks.
not to mention i have to use the marks labbled "E" and notthe marks labled "T"
you would think "T" would be timing. maby it has a purpose but to me its nothing, and should not be there...
87 non turbo wont start, need some advice...please. HotRodV6 MKIII Supra 3 09-02-2010 07:29 AM
Car Died...where to start? Jrew MKIII Supra 4 10-26-2007 02:19 PM
Help Engine cranks but wont start supra210 MKII Supra 1 05-30-2007 12:46 PM
Car Cranks But Won't Start... Please Help Toyota87Supra MKIII Supra 3 04-12-2007 03:06 AM
87 Supra 7M-GTE/AT Engine cranks over but doesnt start... Supra-Boy MKIII Supra 7 03-15-2006 11:38 PM
