Old 09-10-2010, 02:14 PM   #1
cwhepler
cwhepler is on a distinguished road
Default Plug type?
I have an 85 supra, and it seems to foul spark plugs. The last ones were Denso. Is there one that you guys recommend over others?
cwhepler is offline   Reply With Quote
Old 09-10-2010, 06:24 PM   #2
Travis89Turbo
Travis89Turbo's Avatar
NGK Iridum seem to have the best life out of all spark plugs that is what i run in everything including my 200hp snowmobile which is famous for burning plugs but that's a 2 stroke.... the question is why are u fouling plugs. Whats ur timing set at?
stock 2jzge
1999 Ford F350 diesel
2004 Jaguar XJR Supercharged
Old 09-10-2010, 07:21 PM   #3
cwhepler
Not sure what the timing is at. Could that cause a miss that gets better when the car warms up?
Old 09-10-2010, 07:22 PM   #4
Travis89Turbo
Yes it definatly will.. check that first with new plugs. Make sure u set it the right way with the jumper in the diag block. I'll get u a link in about 2 hrs if u need
stock 2jzge
Old 09-10-2010, 07:58 PM   #5
cwhepler
I do need the link. Thanks!
Old 09-10-2010, 11:11 PM   #6
Travis89Turbo
http://www.toyota-supra.info/forums/...mn-timing.html
There ya go bud. Good luck. Let us kno if this helps. Or if its way off.
stock 2jzge
Old 09-11-2010, 03:29 AM   #7
I'd stick with NGKs. As for the fouling try running a plug one temp range hotter.
Stripped plug! batmmannn MKIII Supra 8 05-18-2010 11:29 PM
radiator drain plug 2Fast2Furious MKIII Supra 19 01-02-2010 12:41 AM
supra ecu plug help please nzskate MKIV Supra 3 11-18-2009 01:52 AM
Plug or hose came off back of block f00g00 MKIII Supra 3 05-20-2006 11:01 PM
P type Wheels on an L type Freezenpop MKII Supra 2 04-08-2006 04:52 PM
