Old 02-13-2010, 05:03 PM   #1
JR MK2 SUPRA
JR MK2 SUPRA is on a distinguished road
Default how to get rid of one wheel spin
just want to know how to stop one wheel from spinning.
JR MK2 SUPRA is offline   Reply With Quote
Old 02-13-2010, 07:20 PM   #2
You'd need a limited slip differential (LSD).
Old 02-13-2010, 09:27 PM   #3
JR MK2 SUPRA
this is my frist supra and im learning where can i find limited slip differential lsd?
Old 02-13-2010, 09:33 PM   #4
It's not just a Supra thing.
Do a search of the MKII section and you'll find the details of what to look for and what other vehicles have compatible differentials. Try searching terms such as "diff", "differential" and "limited slip".
Old 02-13-2010, 09:40 PM   #5
Here are a couple threads with relevant info:
http://www.toyota-supra.info/forums/...-required.html
http://www.toyota-supra.info/forums/45497-post8.html
You may find more specific information at www.celicasupra.com... it's a higher traffic MKI and MKII Supra site.
Old 02-26-2010, 02:13 PM   #6
so i must be able to go to lordco and orde rsome part to permanently lock my rear diff?????
Old 02-26-2010, 04:46 PM   #7
You don't want a locked diff unless you're only planning on driving in straight lines. When the car turns the outside wheels spin at a different rate than the inside wheels. Lock the diff and one will be skipping as it's not moving at the same rate as the other and you'll loose traction... in a turn... it's a crap move on anything but a "track only" car.
Go the distance and find a compatible LSD like all those folks before you.
Old 02-26-2010, 11:39 PM   #8
ive actually already got 3
and i wasnt really asking for an opinion just if it was an available part or not....
thanks!
Old 02-26-2010, 11:59 PM   #9
You'd just have the internals welded to lock it. I don't know of any type of kits to do the job.
And you're posting in a public forum... expect opinions.
replacing wheel stud Rahnter MKIV Supra 3 12-10-2008 03:57 PM
Having Trouble Removing the Steering Wheel Chambers MKIII Supra 3 06-30-2008 01:03 AM
Aftermarket steering wheel RTZ MKIII Supra 10 02-07-2008 08:44 AM
Steering wheel off-centre colin172 MKIII Supra 3 10-06-2006 01:41 AM
Steering wheel. lifesnotfair MKIII Supra 11 12-30-2005 12:26 AM
