Old 01-10-2010, 05:12 AM   #1
Frankie J
Frankie J is on a distinguished road
Unhappy FIring order for 84 supra
I am a new user and am also new to cars. I know how to change the plugs and wires but I don't know the firing order or how the cylinders are numbered. Also I was told that the fuel pump is prob bad. Is there a way I can test that? If so, please explain how. Need help and any would be greatly appreciated!!
Frankie J is offline   Reply With Quote
Old 01-12-2010, 12:19 AM   #2
when you turn the car to start, do you hear the Fuel pump click on?
Firing order
http://autorepair.about.com/library/...l-fo-12832.htm
http://www.toyota-supra.info/forums/...-88-turbo.html
Old 01-13-2010, 10:50 PM   #3
Suprademon
Suprademon's Avatar
Suprademon is on a distinguished road
84 has an internal fuel pump. A quick check is to remove your air filter. The metal box behind it connected to the tube to your intake is air flow meter. There is a flapper inside that you can move easily. With the ignition on, stick something in the flap to hold it open. This will cause the fuel pump to engage and you should be able to hear it.
There is also a test lead there that can be jumpered to engage the fuel pump.
This is the link to the Technical Service Repair Manual (TSRM) for the 1986 MKII. Your 84 is not significantly different. It has a wealth of info and detailed instructions for testing.
http://www.cygnusx1.net/Supra/Library/TSRM/MK2/
Suprademon is offline   Reply With Quote
Old 01-13-2010, 11:09 PM   #4
thread in the mk3 section were parts of it discuss a bad fuel pump possibility.
Tyr placing a jumper across FP and B+ in the diagnostic box in the engine bay and then try to start. This bypasses a couple relays and powers the fuel pump directly... it'll help eliminate a bad pump as a possibility.
http://www.toyota-supra.info/forums/...-question.html
Engine error code page from TSRM
http://www.cygnusx1.net/Supra/TechTi...ror_codes.aspx
Old 01-14-2010, 05:26 AM   #5
The MKII's fuel pump check connector, unlike the MKIII, doesn't bypass the ignition switch, EFI fuse, Main EFI relay or the circuit opening relay. These nees to be in known working order and the ignition set to "ON" to use with the FP check connector or the AFM FC switch for a diagnosis.
Do keep in mind that a bad fuel pump may power up and even provide "proper pressure" at very low loads. Checking fuel pressure at high idle and light throttle is a better indication, IMO.
Here's the TSRM's chapter on diagnosing and servicing the fuel pump:
http://www.cygnusx1.net/Supra/Librar...ection=FI&P=44
Old 01-14-2010, 05:56 AM   #6
and that is why is stay in the mk3 section..
Old 01-14-2010, 06:50 AM   #7
There's just soooo much to learn eh? Damn I need some other hobbies... things to fill out my day...
Old 01-14-2010, 09:35 PM   #8
that and I dont have one.. hands on experience helps. I can read all I like but if I cant get out there and do it.. its all just hypothetical.
Correct Firing Order for an 88 turbo spoolin1 MKIII Supra 6 04-03-2006 12:23 PM
