Old 01-07-2010, 10:08 PM   #1
contryman
contryman is on a distinguished road
Thumbs down 85 5 MGE leaks oil
I had our 85 5 MGE engine rebuilt but it still leaks oil. I think it is leaking between the cam shaft housing and the head on the exhaust side of the motor.
Can I remove the cam shaft housing and replace the gasket with out removing the head? Do I need to readjust the valve lifters? What other precautions do I need to be aware of?
I know how to keep the timing correct as I have replaced the head before and put all the bolts back in their original places.
contryman is offline   Reply With Quote
Old 01-08-2010, 03:43 AM   #2
The TSRM for the '86 MKII is available for viewing online. I hope it covers what you need. I know the diagnosis system is different in earlier years though.
Here is the link to the section for working on the head: http://www.cygnusx1.net/Supra/Librar...ection=EM&P=18
I hope this helps.
As for timing, resetting the mechanical timing is simple enough and you'll find it covered in that manual in the Engine Mechanical section and Ignition System. I do not know the procedure for setting the ignition timing, although you should set it after you reinstall the timing belt.
Old 01-14-2010, 12:02 AM   #3
Suprademon
Suprademon's Avatar
Suprademon is on a distinguished road
Yes, it can be replaced without removing the head. Exhaust side should be a bit easier. I haven't actually done it, but here is a good link with instructions and suggestions on gaskets...
http://forums.celicasupra.com/showth...tower+oil+leak
Suprademon is offline   Reply With Quote
Tags
5 mge, 85 supra, cam, oil leak
Rad leaks CanadianBak'inSupra MKIII Supra 7 11-17-2009 07:43 PM
Locating Boost Leaks slader99 MKIII Supra 5 05-21-2008 01:12 AM
Oil leak(s) mattapo MKII Supra 3 12-21-2006 08:20 AM
Targa top leaks!!!! 90' turbo supra brandonsupra MKIII Supra 0 10-23-2006 08:04 PM
Oil leaks on turbo Sath Non-Generation Specific Questions 0 12-04-2005 05:48 PM
