Old 01-02-2010, 09:35 PM   #1
matthew87
matthew87 is on a distinguished road
Default 85 supra engine troubles
i bought this thing two months ago drove it 20 miles or so home ran great i went to start it it went to missing only hitting on 4 or 5 cylinders at a time never missing on the same cylinder all plugs are getting spark belive me there good shocked me every time never loses spark we pulled the tank cause the pump was whining real loud the top of the tank had a rust hole in it about the size of a dime the inside was nasty we changed tanks off a parts car i bought checked it was clean droped in a new pump put it on same thing so i changed the filter still the same sent a head changed out the coil tuned it up wires and plugs still misses what do i check now has a 2.8 inline 6
matthew87 is offline   Reply With Quote
Old 01-03-2010, 02:20 PM   #2
chino1123
chino1123 is on a distinguished road
check the timing and ignition
chino1123 is offline   Reply With Quote
Old 01-13-2010, 11:19 PM   #3
Suprademon
Suprademon's Avatar
Suprademon is on a distinguished road
Did you change the distributor cap and rotor as well as the plugs and wires?
Suprademon is offline   Reply With Quote
1JZ Engine Swap into '89 Supra kyosukerob MKIII Supra 2 10-20-2009 07:49 AM
Engine Management For VVT-i JDM Supra? Mellowdien MKIV Supra 3 10-19-2008 04:00 PM
In Need of New Engine 4 1990 Supra SuperSpartan MKIII Supra 4 05-26-2008 02:54 PM
my mkiv supra wont start after engine change HELP!! gkhawk MKIV Supra 1 08-18-2006 12:40 PM
